how to transfer images to ipad and how to delete images
This is a discussion on how to transfer images to ipad and how to delete images within the iPad Help forums, part of the Apple iPad Discussions category; I am brand new to ipad and in reality most computer stuff. My son placed some of my art on the ipad, but he put ...
Results 1 to 10 of 20
Like Tree3Likes
Thread: how to transfer images to ipad and how to delete images
    32788
    Feb 2011
    North Pole
    I am brand new to ipad and in reality most computer stuff. My son placed some of my art on the ipad, but he put the wrong pictures. I need to remove current and post new. How do I do that?
    VAP likes this.
    119 times
    15,248
    Quote Originally Posted by Santa Claus View Post
    When you're in the iPad's Photo app, touch briefly the thumbnail of the picture you want to delete. It will 'open' up in full-screen. At the top right hand side of the screen you'll see briefly a trash can icon. If you touch that you'll be offered the option of deleting the photo or art work. If you're too slow to 'catch' the trash can icon (it disappears quite quickly, allowing you to see your photo/art in full-screen mode) you can get it back by briefly touching the screen.
    There are several ways that you can get new photos or art onto your iPad.
    (a) email the photos to yourself and receive them on the iPad. The photo will display as an attachment. If it's a small file, then the iPad will automatically download it and will display it immediately in the iPad's email app. If it's a big file then it will display an icon of the attachment and you'll have to touch the icon to be offered the option to download it. Once it's downloaded and displayed on the screen if you touch *and hold* the image you'll be offered the option of opening it in the Photos app.
    (b) you can sync your iPad with your PC using iTunes and transfer the image that way. But using iTunes is not really straightforward if, as you say, you're not that familiar with computers. So I would use another method
    (c) you can use a 'cloud server', such as Apple's MobileMe, which gives you some disk space on their server. With a MobileMe subscription you can upload and download files to the MobileMe server (called iDisk) from your PC using a web browser. iDisk has a folder structure that includes Photos, Music, Documents etc and you can create new folders there (Control-N). With the iDisk app on your iPad you can then download/upload files from the Apple iDisk server to your iPad.
    (d) Apple sell an 'adaptor' that plugs into the socket on the bottom of the iPad that will accommodate an SD memory card. You can transfer all your art/photos to an SD card and insert it into that adaptor. The iPad automatically recognises the photos/art if they're in a format that the iPad can understand and will offer you the opportunity to upload them to the iPad. It places them in the file space used by the iPad's built-in photo app
    32861
    Feb 2011
    do you want to keep the pics on your ipad or just delete them and upload the new ones?
    18578
    9 times
    Oct 2010
    Virginia, usa
    608
    First, you should remove the pictures currently in the Camera Roll (Photos), so you won't be duplicating everything. You can do this by connecting the iPad to your computer and then going into iTunes, and under "Devices" on the left hand side of the screen, click on your iPad name. A window will open up with tabs on the top. Select "Photos", under "Photos", un-check "Sync Photos from..." , and sync, this will delete all of the photos on the iPad
    You need to setup a folder, on your PC under "My Pictures", such as "iPad Pictures" and make all of the folders you want, with the pictures you want in them (copy, move or drag and drop, your choice), under that folder. Then go into iTunes, under PHOTOS and select "Sync Photos from" and change "My Pictures" to "Choose Folder" and then choose the folder you created "iPad Pictures" open it and select the folders you want to sync to the iPad. Then sync them.
    Good Luck
    Pocobear
    13303
    Aug 2010
    thailand
    Hi Tim the way you say to delete a photo does,nt work for me.when I open photos it shows all my pictures,then if I open one it opens full screen yes but no delete bin appears.If I touch the arrow as if to send,at the top right hand side it brings up e/mail ,copy,or delete,top left hand side.Then if I touch a photo a tick appears on it.If I press e/mail or copy ok,but if I touch delete,which is in bold red nothing happens,only ideas,
    34396
    Feb 2011
    19
    pocobear - tx for the info. I managed to delete all the photos as you instructed
    , next I'll be setting up the folders as you suggest. Once I've done that and downloaded them to my iPad - can I expect each folder to show up as an individual album? If not - how to make it so? My other problem is the same as dick quinn above - any suggestions?
    1523 times
    Walla Walla, WA
    15,432
    You can only delete photos that are in the Saved Photos album. This is the album where pictures get saved on the iPad when you send them to the Photos app from another app, save them Mail or a browser, or take a screen shot.
    All other photo albums are synced from the computer, and may only be changed on the computer. Photos was never designed to be more than a way to store and show pictures. It has no management features for sorting, editing, or creating photos and albums.
    34396
    Feb 2011
    19
    iPad photos
    @ twerppoet - thanks for your insight. If I understand you correctly, Photos does NOT have the capability of storing photos in specific categories? Is there no way to assign photos to a specific category, e.g. Sports, Family, or Landscapes etc.in iPad? In other words, are all photos downloaded to iPad stored in one common area only? Be kind, for I am aged and unfamiliar with this device. Thanks in advance.
    6872
    Jun 2010
    Melbourne, Australia
    22
    if you put your photo's in folders Like Pocobear said then that is the category they will be in on the iPad
    1523 times
    Walla Walla, WA
    15,432
    As Drak said, you put the pictures in folders on the computer.
    Name the folders with your categories, and put the pictures in the corresponding folder. The folders will show up as albums on the iPad after you sync. The names of the albums will be the same as the folders.
    Follow Pocobear's instructions and you will be fine. And if you don't get it perfect the first time, you can keep re-arrainging the pictures on the computer and re-syncing until you're happy with the results.
    Nickg8 likes this.
  1. Importing Images Mac Book Pro to iPad
    By epoche in forum iPad General Discussions
    Last Post: 10-24-2013, 03:19 AM
  2. Getting Images OFF the iPad?
    By RAC in forum iPad General Discussions
    Last Post: 01-01-2012, 06:28 AM
  3. cannot delete images off ipad (13 gig worth)
    By imreasc in forum iPad Help
    Last Post: 01-04-2011, 09:48 AM
  4. how to preload images in an ipad application
    By imayank in forum iPad General Discussions
    Last Post: 12-27-2010, 07:58 AM
  5. Getting images onto the ipad
    By 3rdfoundation in forum iPad General Discussions
    Last Post: 12-25-2010, 08:14 AM
how to delete downloaded photos from ipad
how to delete downloaded pictures on ipad
how to delete or transfer photos from the i-pad to the computer
how to delete picture download from a computer to an ipad
how to delete pictures from pc in ipad
how to take photos off the ipad that has been downloaded from a computer
moving my photos onto my ipad when i click apply nothing happens blocked?
why am i erasing folders on ipad after transferring photos from pc
