First timer help
This is a discussion on First timer help within the iPad Help forums, part of the Apple iPad Discussions category; Hi Guys, First time here so thanks in advance and be gentle. i should add that I am from the Uk too if that helps ...
Results 1 to 8 of 8
    32697
    Feb 2011
    9
    First timer help
    Hi Guys,
    First time here so thanks in advance and be gentle. i should add that I am from the Uk too if that helps explain my questions..
    Firstly I currently don't own any Apple products and have never used Itunes, I downloaded the latest version of IT last night so i will spend the next few days playong around with it.
    I am off on holiday to Florida in late May and I intend to visit the Apple store near our hotel and buy an IPAD, not quite sure if I will opt for the new model if it is out by then or grab the current version as a bargin.
    I need a little help on how I prepare in advance.
    1) I have read that I need to activate the IPAD via Itunes on a PC, is there a way around this as my PC will be back in Blighty. Is it something one of the chaps in the apple store could do.
    2) Can I buy apps in advance and then download them when I get my IPAD in the states.
    3) I also want to be able to put some PDF and EPUB book on when I am out there. Could I open a DROPBOX account and load them onto that at home, then down them to my IPAD.
    4) Can I do the same as above with music and video or can that only be down through Itunes and my PC.
    I know there is a lot there, if you can only answer a bit feel from to reply.
    Thanks in advance.
    Chris
    Ps, feel free to point out any down sides to buying the IPAD in the USA to start with.
    19182
    3 times
    Oct 2010
    Israel
    890
    1. No
    2. Yes. buy and download to iPAD, You can sync it later to iTunes
    3. No need for DropBox for PDF and ePUB. Can load directly to iPAD later.
    4. Same with Music
    Why dropBox for keeping a file tha later on be transfer to iPAD any way. Put the files on a USB device for keep.
    Once you have your PC with iTunes, strat transferring.
    Think before you Sync Since you may Sink
    The More Tweaks you have - Less Memory is left
    32697
    Feb 2011
    9
    Sorry I should have been clearer.
    I want to use the PDF's, EPUB books,Music and Video straight after I have bought it if possible while I am still in America.
    Hence why I need to do it all without my PC.
    Cheers
    Chris
    iPad Guru
    30446
    12 times
    3,196
    The problem is that you need to activate your iPad via iTunes and in turn iTunes needs to be activated with your account for it to work with your apps.
    However, you might connect your iPad at the Apple Store to activate it with their account. When I got my iPad replaced, I simply connected the new one to one of the MacBooks at the Sfore, which then enabled me to use the iPad without having it synced with my one iTunes.
    However, I don't think that you can use any content which is explicitly linked to your itunes account in this state. So you might be limited to the preinstalled apps.
    iPad Ninja
    5787
    22 times
    Jun 2010
    2,282
    Your timing is great as the iPad2 is almost certain to be out by then and if apple follows it's previous practice it could be several months later before it arrives in the UK.
    You can certainly get it activated in store and even open an iTunes account before you travel and download apps. The trick will be accessing that account from Fl..
    Actually it would just be accessing the uk iTunes store as if you have bought apps you can redownload them for free.
    Thankfully it remembers your purchases.
    32697
    Feb 2011
    9
    Thanks for your replies guys.
    Am I right in understanding that I can now create an I tunes account in the UK.
    Then buy the any apps I fancy ahead of time.
    Get the US Apple store to activate my IPAD
    Then log into the uk app store direct from my IPAD and download the apps bought from the UK.
    All without the need of a PC.
    iPad Ninja
    5787
    22 times
    Jun 2010
    2,282
    I haven't needed to do this myself but it should work. Hope someone can confirm it does from experience.
    Apple (United Kingdom) - iPad - The best way to experience the web, email & photos
    iPad Ninja
    5787
    22 times
    Jun 2010
    2,282
    Wish the links posting didn't always do that. The bit you need to remember is that you put /uk/ipad/ after apple.com
  1. Screen/Sleep timer settings
    By Ninb91284 in forum iPad FAQ
    Last Post: 01-11-2012, 12:08 PM
  2. Camera Self-Timer Save iPad!
    By robertlc in forum iPad General Discussions
    Last Post: 08-24-2010, 12:25 PM
  3. Obligatory 1st timer post
    By briloop in forum New Member Introductions - Site Assistance
    Last Post: 03-22-2010, 02:45 PM
are there any ipad sleep timers for videos
can you set a timer on ipad camera?
how to put timer on ipad
how to set camera timer on ipad 3
ipad sleep timer with video
sleep timer for ipad when watching video
sleep timer ipad video
video sleep timer ipad
