Problems loading music
This is a discussion on Problems loading music within the iPad Help forums, part of the Apple iPad Discussions category; Can someone tell me what I am doing wrong I added 182 music tracks to my iPad, everything was fine and playing okay. I am ...
Results 1 to 3 of 3
    31942
    16 times
    Feb 2011
    Staffordshire, UK
    199
    Can someone tell me what I am doing wrong I added 182 music tracks to my iPad, everything was fine and playing okay. I am now away from home come to play music and it says there is non loaded. Did I do something when I synced to the computer to add a new program.
    19182
    2 times
    Oct 2010
    Israel
    891
    You may Sync Programs, and yet skip syncing Songs.
    You need to take a close look, on you iTunes what you asked it to Sync.
    If The original Songs are no longer on the iTune library, and you instructed iTunes to Sync, it is as if you asked iTunes to delete all songs from the iPAD.
    Do you have you NEW song running OK on the iPAD, or nothing at all ?
    I the iTunes is not supposed to Sync Songs. And yet you can't see them on you iPAd Application, Try a full restart on the iPAD before you start any troubleshooting on the iPAD.
    Think before you Sync Since you may Sink
    The More Tweaks you have - Less Memory is left
    31942
    16 times
    Feb 2011
    Staffordshire, UK
    199
    Thanks Peled, I added a couple of new songs and then did a sync to update, I then unpluged from the computer and checked they were all there, which they were. I went to play music yesterday and there is nothing in the library.
    This happened last week but was at my comp at the time so just did another sync and they were all back.
    Not sure what you mean by a full restart.. I do a complete shutdown when not being used for a while.
  1. itunes problems loading on iPad
    By ipadlover55 in forum iPad Help
    Last Post: 01-29-2011, 05:37 PM
  2. Apps not loading,
    By kstodd in forum iPad Help
    Last Post: 11-10-2010, 03:17 AM
  3. Freezing when loading
    By Howard kelly in forum iPad Help
    Last Post: 10-03-2010, 03:23 PM
  4. I-pad or netbook??? DSL loading
    By Kenworth in forum iPad Help
    Last Post: 08-02-2010, 06:49 PM
  5. iPad App Store keeps loading !
    By Ryan in forum iPad Help
    Last Post: 05-25-2010, 08:49 PM
ipad music not loading
ipad music troubleshooting
ipad troubleshooting for loading music
loading music on ipad
loading music to ipad
music not loading on ipad
music player not loaded ipad
music with no loading
no loading music
play music there was a problem loading
songs not loading to ipad
troubleshoot songs load to ipad
