Help with PrintCentral
This is a discussion on Help with PrintCentral within the iPad Help forums, part of the Apple iPad Discussions category; Just purchased PrintCentral for use with my Epson Workforce 600 printer. It prints the 2 line text test fine, but that's it. Everything else is ...
Results 1 to 2 of 2
    5740
    6 times
    Jun 2010
    Long Beach, MS
    769
    Exclamation Help with PrintCentral
    It prints the 2 line text test fine, but that's it. Everything else is just a line of characters or gibberish.
    The developer's website is no help as they want you to install software on a computer to print to the printer through the computer.
    I had heard this app was greatcand would work. Can anyone help or have I wasted $10.00?
    116 times
    15,249
    What version of iOS are you using? Some of the features only work with iOS 4.2.1. I must admit that I've struggled with PrintCentral a bit but perservered and finally got it working OK. I guess you've tried all the usual things - soft reset on the iPad, turn the printer on and off - and so on. Sorry not be able to offer anything more specific but it is worth perservering. A couple of other things - if you're using PrintCentral in iOS 4.2.1 and want to use the 'in app' printing feature (i.e. the ability to use the AirPrint print menu - where PrintCentral 'shows up' as a printer) then you need to have PrintCentral running in the background - i.e. it should show up in the Multi-Task bar when you 'double tap' the Home button.
    Good Luck
  1. printcentral best print solution
    By col.bris in forum iPad App Announcements
    Last Post: 04-15-2010, 04:13 PM
epson workforce 435 and ipad
epson workforce 435 how to use ipad
epson workforce 545 ap
epson workforce 545 is offline error on ipad
epson workforce 545 print from ipad
ipad print driver for epson workforce 600
ipad won't print to epson workforce 435
ipad workforce 600
latest app for ipad4 to print to epson workforce 545
print central help
print from ipad to epson workforce 545
workforce 435 ipad
