Alarms and system sounds
This is a discussion on Alarms and system sounds within the iPad Help forums, part of the Apple iPad Discussions category; I know it's about the iPad, but I assume settings are the same for iPod (which I bought recently as an "iPad on the go" ...
Results 1 to 2 of 2
    iPad Junkie!
    14151
    Sep 2010
    189
    I know it's about the iPad, but I assume settings are the same for iPod (which I bought recently as an "iPad on the go" as it fits better in my pant's pockets).
    If I turn off the alarm sounds, I also have my system sounds off. So far so good. But I'd like to have system sounds off and alarms from the clock or calendar still sounding. Is there a setting I may have overlooked???
    1545 times
    Walla Walla, WA
    15,467
    You can individually turn system and alert sounds on/off under Settings > Sounds. Look under Settings > Notifications to turn off alert sounds for third party apps individually.
    That is using a second generation iPod running the current OS.
    The same sound settings can be found on the iPad under Settings > General > Sounds. Hopefully a current generation iPod will have them in one of these two places.
    Don't know if that is what you are looking for, but it is all I could find.
  1. Replies: 6
    Last Post: 10-24-2012, 03:41 PM
  2. System Clock
    By Hawkmech in forum iPad Apps
    Last Post: 04-07-2011, 12:31 AM
  3. iPad sets off store security alarms?!?!
    By graywolf in forum iPad General Discussions
    Last Post: 12-31-2010, 12:55 AM
  4. System clock app
    Last Post: 08-01-2010, 01:49 PM
  5. Slide sounds?
    By steve56 in forum iPad Hacking
    Last Post: 05-13-2010, 05:07 PM
how do i change the alarm sound on my ipad
how do i turn off the alarm on my ipad
how to change alarm sound on ipad
how to shut off alarm on ipad
how to turn off alarm on ipad
ipad alarm wont turn off
ipad how to turn off alarm
