Low memory warning
This is a discussion on Low memory warning within the iPad Help forums, part of the Apple iPad Discussions category; Hey all.. Got a question. I use two programs simultaneously and when using these programs I constantly get a low memory warning. I shut everything ...
Results 1 to 4 of 4
    22828
    Nov 2010
    Low memory warning
    Hey all.. Got a question. I use two programs simultaneously and when using these programs I constantly get a low memory warning. I shut everything else down and make sure these are the only two programs running. The first program is pages and the second is Bible HD.. Is there a way of allocating more memory for desktop usage or is there a way of shutting off that warning? Thanks
    18578
    10 times
    Oct 2010
    Virginia, usa
    608
    I don't know of any way to turn off the warnings or change memory allocations. One thing to try is to shut down the iPad, hold power button till slider appears , slide it to off, wait a few seconds and restart. This should clear memory, hopefully allowing you to run both programs together. Otherwise an iPad with more memory would be in order.
    Good Luck
    Pocobear
    22828
    Nov 2010
    I have the 64gb 3G is there something better. I am more referring to the desktop memory.
    iPad Ninja
    5787
    21 times
    Jun 2010
    2,282
    You're limited to 256mb which is shared with the graphics chip.
    The actual amount you have to run apps with is much less in practise
    Just fired one up and it says Wired:199mb, Active:23mb, Inactive:14mb and Free:9mb......ymmv but I bet it's fairly similar.
    (This is using an app called iMonitor by HandyPadSoft.)
    Hopefully the new iPad will see at least a doubling of ram.
  1. Memory Map App
    By littlebuddha in forum iPad Apps
    Last Post: 03-31-2012, 08:58 AM
  2. Low Memory!! Is there an app for that?
    By stever in forum iPad Apps
    Last Post: 06-09-2011, 10:17 AM
  3. Memory help
    By maxsassy in forum iPad FAQ
    Last Post: 01-09-2011, 03:51 AM
  4. What exactly does memory tap do?
    By rjleamaster in forum iPad Hacking
    Last Post: 07-19-2010, 09:01 PM
  5. Not enough memory available...
    By Matth3w in forum iPad Help
    Last Post: 05-27-2010, 06:42 PM
apple tv 2 low memory warning
apple tv 2 memory warning
apple tv 2 running low on memory
apple tv low memory
apple tv low memory warning
apple tv memory warning
ipad low memory warning
ipad low memory warnings
ipad low on memory warning
ipad memory warning
low memory warning ipad
low memory warning on ipad
