Safari, greyed out and cant shift it - Stuck
This is a discussion on Safari, greyed out and cant shift it - Stuck within the iPad Help forums, part of the Apple iPad Discussions category; I am travelling in Europe and as I have done before, I have paid up to Swiss Mobile at the hotel hotspot to get Wi ...
Results 1 to 10 of 16
    30983
    I am travelling in Europe and as I have done before, I have paid up to Swiss Mobile at the hotel hotspot to get Wi Fi connected. The first time I logged on no problem. But at the second attempt,the login screen on Safari is greyed out and I cannot use any of the functions. I cant get rid of it. My instincts tell me that the issue is probably with safari and not the wi fi provider.
    Any clues out there.
    Barney
    19182
    3 times
    Oct 2010
    Israel
    890
    Could it be that that screen is Flash ?
    Think before you Sync Since you may Sink
    The More Tweaks you have - Less Memory is left
    30983
    I found a similar query to mine on another forum. Apparantly this issue is becoming quite common and is related to specific software version.
    I was advised to hold the on / off button and the "home" button at the same time for at least 10 secs or until the Apple logo appeared on the screen.
    I did and it worked.
    Hope this helps anyone else with the same problem.
    Barney
    19182
    3 times
    Oct 2010
    Israel
    890
    Quote Originally Posted by BarnyBoko View Post
    Barney
    Glad to hear that a reset helped.
    52829
    May 2011
    Pleasanton, CA USA
    Barney, this worked for me with a similar, maybe identical problem: the safari browser was seemingly active in that I could type search terms into the Google search field and see the results. However, the web page that came up was greyed out, as was every other web page. I could not find a direct fix within safari, but by rebooting the iPad-2, I cleared the safari problem. So hold down the power button (top-side) and the task screen button (front, circular) until you see the screen go into a power-down mode. After the iPad-2 reboots you power on and the safari problem is cleared. There may be other solutions, but I am a novice iPad-2 user and this worked.
    52830
    May 2011
    Quincy, IL
    15
    Can you give me help in safari? When I open a www site and then click on the URL for a new page on the site, I can't return to the original page. The is no working backup arrow. I have been using Explorer until now.
    42186
    7 times
    UK
    765
    Quote Originally Posted by Kjweede
    in the top left, next to the right arrow, there is 2 square box one overlapping the other with a number in it
    that essentially is the number of tabs/windows you have open, it sounds like that when you opened the new link that is has opened a new tab/window, and because that is a new tab/window, the site it opened is essentially the first site, so won't be able to go back
    58380
    May 2011
    Ipad reboot
    I have come to the conclusion having used an Ipad for less than a week that it is necessary to reboot the thing even more than my Windows PC. The system and/or apps supplied with the system are far from bug proof. Scary.
    hfw
    hfw is offline
    17905
    Oct 2010
    7
    Quote Originally Posted by landbuilder
    Is it possible that you've installed some misbehaving softeware? I tend to try out a lot of apps, and have come across several that just don't want to play nicely. It's sometimes a little rough to figure out, because that app may or may not still be running or may not have cleaned up after itself. I would suggest saving any data you need then deleting all the non-original apps. They'll all be waiting for you at the App store. Then do a reset. Now install the apps you've deleted a few at a time. For me it's easiest to create a "sandbox" by putting their icons on a separate page. Play a while. If all goes well you can move those icons off the sandbox page and into their regular spot.
    I continue to use the sandbox approach for new apps, using the rest of the normal functions as always. If everything behaves for a couple days, the newbies can be let out of quarantine.
    Does this make sense?
    59020
    May 2011
    I have a brand new ipad2 and am finding that safari freezes with grey screen at least four times a day. It is abysmally unreliable and I have no apps downloaded yet.
    Is this a known problem and if so, is there a fix due. I have never seen a more appalling stability on any device- it is going back to apple if the only fix is "reboot the device"
  1. stuck
    By TillysWilly in forum iPad Hacking
    Last Post: 01-20-2011, 03:23 AM
  2. Applications greyed out in Itunes
    By portmacquarie in forum iPad Help
    Last Post: 11-29-2010, 11:26 PM
  3. shift + F6
    By dustin002 in forum iPad Help
    Last Post: 09-08-2010, 07:40 AM
  4. Safari stuck on "Apple-Legal-iTunes" screen
    By iBean in forum iPad Help
    Last Post: 06-09-2010, 06:56 PM
  5. Booq Shift M - Denim
    By Seadog in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 05-20-2010, 02:50 PM
clear history greyed out ipad
clear history greyed out on ipad
clear history in safari greyed out
clear history is greyed out on ipad
how to remove greyed out app on safari ipad
ipad screen is grayed out
my ipad screen is greyed out
safari clear history on ipad grayed out
