Results 1 to 4 of 4
    28421
    Sweden
    5
    Camera connection kit, not working correct?
    Hey, Got a problem with my iPad (16GB, 3G/WiFi) and the accessory camera connection kit. I've plugged it into my iPad, connected the USB-cable between the camera (5D MkII) and started them both:
    Nothing happens.
    From the start I thought the problem was that I had more than 1500 pictures on the camera, that it would take longer for it to come up/load. Nothing happened at all though, I tried to remove the cable, restart both units and so on. All of a sudden I see that all pictures is coming up on the iPad, but in the same second I removed the cable because I didn't believe it worked. When I tried again nothing happens.
    Then I removed all pictures but ONE - but I still have the same problem.
    Is something broke or what?
    iPad Ninja
    5787
    21 times
    Jun 2010
    2,284
    Doesn't sound like it.
    Transferred some this afternoon and it's fairly slow with largish files. Obviously needs to convert them as well as import which may be the problem.
    Best thing to do when these sort of things happen is switch everything off and walk away for five minutes before trying again.
    Normally when you start you see the dotted outline of images , which then slowly fill up with thumbnails. You can then choose the ones to transfer by tapping on them.
    They'll show up in their own folder titled Last Import.
    28421
    Sweden
    5
    Yep, the time it worked thats exactly what happened. "Pictures" popped up immidiately and showed the dotted outline of all images, but as said I accidentally removed the cable before they were loaded completely.
    Now I even cant get the dotted outline to come up, I'm gonna try to turn everything off for a while though!
    34014
    Feb 2011
    California
    I have a problem with mine too - I used to just put my card in the carder reader and plug it in and everything used to be just fine. Would take a while to load since I take so many pictures but they eventually would..two days ago I plug it in and NOTHING happens, nothing has been changed on my computer, the card nor the camera. It's like my iPad is not recognizing the camera connector reader. So frustrating..
  1. Camera Connection Kit
    By jackpg in forum iPad OS
    Last Post: 11-30-2010, 04:59 AM
  2. Camera Connection Kit stopped working
    By MadOx75 in forum iPad Help
    Last Post: 09-11-2010, 11:03 AM
  3. Replies: 3
  4. Camera Connection Kit with Panasonic LX3 Digital Camera
    By Atwell in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-23-2010, 08:35 AM
  5. Camera connection KIT
    By SunnyFL in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-16-2010, 11:10 PM
camera conncetion kit for ipad not working
camera connection kit for ipad not working
camera connection kit ios not working
camera connection kit not working
i plug in an apple camera connection kit to my ipad and nothing happens?
ipad camera connection kit ios6
ipad camera connection kit not working
ipad camera connection kit not working 6.0.1
ipad camera kit not working
nothing happens when i plug in my camera connection kit
why is my camera connection kit for my ipad not working
why is my camera connection kit not working
