Help! I am have tried tirelessly to organize my apps into folders like on my iPhone and iTouch, but it won't work! I touch them until they wiggle, move them over other apps and then the other app moves and I can't drop it on top! Please help me!!!
This is a discussion on Help Organizing Apps within the iPad Help forums, part of the Apple iPad Discussions category; Help! I am have tried tirelessly to organize my apps into folders like on my iPhone and iTouch, but it won't work! I touch them ...
If you have versions of iOS 3.x.x you can't make folders, it takes iOS 4.2.1 to enable that feature. You can upgrade through iTunes to iOS 4.2.1.
Here's where you can find the iPad manual for iOS 4.2.x
Apple - Support - Manuals
You can check what version you have in Settings > General > About > Version.
Hope this helps.![]()
Good Luck
Pocobear
Thank you SO SO SO much! I am going to update it now!
Really appreciate it. It's been driving me crazy![]()
