i am to new to apple i need a bit of help please ?
This is a discussion on i am to new to apple i need a bit of help please ? within the iPad Help forums, part of the Apple iPad Discussions category; Hi i have a ipad 32GB i cant get and flash player to work i got the ipad to edit my photo's on a website ...
Results 1 to 6 of 6
    28462
    england
    Hi i have a ipad 32GB i cant get and flash player to work i got the ipad to edit my photo's on a website called flicker ? but say need abode flash ? is they any way around this i have downloaded about 3 webb browers and none work ? and i cant use my ipad to right back on forums? i have to us my pc ? thanks
    7489
    126 times
    Jun 2010
    Sacramento, California
    14,962
    There is no flash on the iPad. There are some browsers/apps that most complain do not work.
    I'm guessin you didn't research that little bit of info before buying, did you?
    Marie ~
    Forum Rules. Please Read.
    appleforums.net
    epb
    epb is offline
    4438
    10 times
    May 2010
    Chicago, IL
    865
    Flash isn't supported on the iPad. If that's a big deal, you should return it.
    If the text box is grayed out in your browser, either click the a/A box in the upper right corner.
    You had your entire life to prepare for today.
    22633
    Nov 2010
    Illinois/USA
    6
    Not sure the skyfire app will help you but you can check it out and decide for your self. Check it out in app shopper.
    J.D
    J.D is offline
    28614
    Orlando
    102
    Oh sorry to hear that bud but you should have done your research on the device before purchasing, if you want a device for flash you should either be using a PC, laptop or start looking at smartphones and other PC tablets.
    In future, Google it before buying
    Regards,
    J.D
    _______
    iPhone 4S Owner (16GB)
    The New iPad Owner (16GB - Wi-Fi)
    iPod Touch Owner (16GB)
    579 times
    Dayton, WA
    13,187
    Though you can't use flash, it is still possilbe to add, delete, and edit your photos on Flickr. It's just a bit awkward.
    Using a Flickr app like FlickStacker you can upload and download photos to Flickr, with reasonable control over your tags, albums, etc. When you do this the photos end up in the Photos app on the iPad. This turns out to be a good thing, since most image editing apps have the option to load and save to the Photo app's gallery as well.
    So, you download your picture from Flickr, using your app of choice. It ends up in the default photo app on the iPad. You open your favorite image editor [there are dozens of choices] and import the picture from Photos. Edit, export back to Photos, and then use your Flickr app to upload it again.
    See, simply convoluted. And you have to learn the quirks and methods of each app you chose, instead of just one web site.
    It does have some advantages though. You are not limited to Flickr's editor. You can pick the one you want, or pick a dozen of the cheaper one trick ponies.
    Also, while editing the photos you won't need to be connected to the internet. Just when you need to upload or download them. So you can grab a bunch you want and work on them any time you've got the iPad handy.
can't view pictures on jd parts on ipad
flicker ipad upload
how to download photos from ipad to flicker
how to upload photo to flicker from ipad
how to upload photos to flicker using ipad
ineedhelpwithnew ipad
o ipad 1 flickering when on facebook photos
