Screen rotation issue
This is a discussion on Screen rotation issue within the iPad Help forums, part of the Apple iPad Discussions category; I tried to search the forum for an answer before posting, but could not find anything. Quick question. I have the latest OS (4.2.1), no ...
Results 1 to 7 of 7
    28152
    Quick question. I have the latest OS (4.2.1), no mods to my iPad whatsoever. I've had my iPad since early October, so its not new and did work correctly in the past.
    Here's my problem. The screen no longer rotates when I'm looking at email. All other apps work fine and the screen rotates as normal. Is there a fix for this or something I may be overlooking?
    Thanks...
    7489
    126 times
    Jun 2010
    Sacramento, California
    14,962
    The screen rotation lock is not on the side anymore. It is a soft key in the ipad.
    Double tap the home key and swipe right. There it is.
    Marie ~
    Forum Rules. Please Read.
    appleforums.net
    19182
    2 times
    Oct 2010
    Israel
    891
    Think you need to be a bit more specific , regarding the kind of mail you are using/
    I have on my iPAD 3 kinds:
    1. Exchange
    2. Gmail
    3. Other.
    All working fine - Rotating properly.
    Think before you Sync Since you may Sink
    The More Tweaks you have - Less Memory is left
    28152
    Quote Originally Posted by SweetPoison View Post
    Thanks but I already checked that. Mail (all mail gmail, me, etc...) was the only app that would not rotate. The lock you refer to locks/unlocks all apps and is not app specific. Called Apple and the issue was resolved.
    31101
    sweden
    can you please share how you resolved it?
    28152
    Go to settings and tap on reset. Very simple. The tech at Apple had no record of anyone having the issue. I've used it now a handful of time to correct it.
    iPad Enthusiast!
    1302
    Mar 2010
    New York
    31
    Real resolution of rotation problem
    I too had the problem of the mail app no longer rotating in the iPad after installing an OS update. Resetting the iPad did fix it temporarily, but the problem always came back. I talked to Apple about it and they suggested that the problem was due to some sort of interaction with another app.
    This was proven to me when I replaced my iPad with a new iPad 2 and had the exact same problem.
    The solution? I installed iOS 4.3.2 the other day and, lo and behold, the problem is gone! Guess it was some kind of bug in the OS that has finally been corrected.
    soon to be replaced by iPad 2 same model
  1. screen size issue
    By vsstanton in forum iPad Help
    Last Post: 02-05-2013, 06:07 AM
  2. Who wants their screen rotation button back?
    By newfmp3 in forum iPad OS
    Last Post: 01-29-2011, 02:04 PM
  3. Screen rotation gone after firmware update??
    By ken2step in forum iPad Help
    Last Post: 12-24-2010, 04:23 PM
  4. Replies: 16
    Last Post: 12-20-2010, 06:16 PM
gmail not rotating on ipad
ipad 3 screen rotation problem
ipad email rotation
ipad no longer rotates
ipad rotation issues
ipad rotation not working
ipad rotation problem
ipad rotation problems
ipad screen no longer rotates
ipad screen rotation problem
rotation ipad not working
trouble with ipad rotation
