1st Problem with instability
This is a discussion on 1st Problem with instability within the iPad Help forums, part of the Apple iPad Discussions category; 2 weird things are happening, 1st as it is pulling up a web page the screen flashes back and forth between sizes and zooms in ...
Results 1 to 4 of 4
    485
    2 times
    Feb 2010
    Dakotas
    266
    1st as it is pulling up a web page the screen flashes back and forth between sizes and zooms in and out
    2nd on a text input box the space bar starts tapping out spaces on its own.
    Powered off and seemed to be ok then fritzed again.
    Hoping it could be from a program I installed. Unfortunately have downloaded several over last few days so hard to tell which one.
    Would the easiest thing to do is just delete these last few programs and see?
    iPad Master!
    6869
    4 times
    Jun 2010
    California
    1,278
    Try a reboot, power button/homebutton at the same time until apple appears and restarts. Try a Restore from itunes.. Are you jailbroken? Different things happen with that so try the hacking forum to compare apps for troubleshooting if you are. Good luck!
    485
    2 times
    Feb 2010
    Dakotas
    266
    Not Jail Broken, have tried itunes restore but will try the reset
    iPad Junkie!
    16514
    Oct 2010
    Somewhere?
    111
    Probably your screen protector is the culprit,often happened to my smart phones but never in iPad though. If you have some sort of screen protector on such as zagg,but if you don't have a screen protector then it's probably the finger,I often find myself wondering why the websites zoom IN when I try to scroll,and find my thumb on the screen corner or my sleeve pressing return or l key while typing. So check for these too,if these are not the issues then probably an app or even a defected screen might be the issue but it all depends. Just try a reset first and then see.
    iPad 3G (32GB)
    iOS 4.3
    iPad - The awesome tablet that matters
  1. BCC problem
    By Dream in forum iPad Help
    Last Post: 12-18-2010, 09:04 AM
  2. App problem
    By Coy886 in forum iPad Help
    Last Post: 12-02-2010, 01:14 PM
  3. problem with 3G!!!
    By bahram in forum iPad Help
    Last Post: 11-01-2010, 06:54 AM
  4. Wi-fi problem
    By Simonj in forum iPad Help
    Last Post: 10-10-2010, 09:00 PM
iapd 2 instability
instability connection ipad
instability ipad 2
instable ipad
ipad 2 instability
ipad 2 program instability
ipad help wiith instability
ipad instability
ipad instanility
ipad screen instability
