help with WIFI issues
This is a discussion on help with WIFI issues within the iPad Help forums, part of the Apple iPad Discussions category; I purchased my ipad in november and its happily been connecting to my WIFI router, until the last week or so. it stays connected all ...
Results 1 to 9 of 9
    18454
    15 times
    Oct 2010
    960
    it stays connected all the time, its at full signal strength. I connect to a website it loads half way and then nothing.... then safari cannot connect message appears.
    I go to settings, WIFI, disconnect and then reconnect, and then its fine, for maybe half an hour to an hour.
    its very annoying, I can't seem to pinpoint the problem.
    I know theres a lot of WIFI problems but mine doesn't seem to be the same.
    is there any diagnostics tests I can do to check to see if its my router??
    i'm on OS 3.2.2, and my router is a sky sagem if thats any help.
    cheers
    32GB WIFI/3G 'The New ipad'
    Banned
    14962
    Sep 2010
    Louisville, KY - USA
    615
    Unplug the router, wait a min or so, then plug it back in. Sometimes, you will need to unplug and replug in the modem as well (if it is separate) in which case, unplug the modem, then router and wait a min. Plug everything back in starting with the modem then the router.
    You can see if you are getting a valid IP by going into the Settings, Wifi and then hitting the blue arrow by your connection. if it starts with 169, there is an issue with the router. That means it isn't pulling an IP from DHCP.
    18454
    15 times
    Oct 2010
    960
    Quote Originally Posted by deckyon View Post
    OK thanks for that, i'll try that. one thing worth mentioning is that my laptop, phone and PS3 all seem to connect with no problem?
    28014
    Arctic tundra...well, Wisconsin at least
    I am having exactly the same problem. Resetting the router/modem do not fix the iPad issue and it is further isolated to the iPad since, like addios, I have noticed that all of my other devices have no problem connecting. The only other info I can add is that it only started happening for me after the upgrade to iOS4.2. Prior to the upgrade, I had no connectivity problems at all. The other thing I am noticing is that pages load much more slowly and it times out on my mail as well. So, it def seems like a problem with the iPad WiFi and not just Safari. I hope someone has a fix for this.
    Banned
    14962
    Sep 2010
    615
    What IP address is showing on the iPad? Does the iPad show up in the DHCP list on the router?
    18454
    15 times
    Oct 2010
    960
    where would I find the DHCP list?
    cheers
    4993
    3 times
    May 2010
    St.Louis Mo
    420
    I think some of the experts need to make a list of all the weird sounding names,such as DHCP,Static,and the others associated with the Wi-Fi networking. It would be nice to know what they mean and what they do.
    Al.
    18454
    15 times
    Oct 2010
    960
    Quote Originally Posted by Al Rogers View Post
    Al.
    I know what it means lol (Dynamic Host Configuration Protocol) I just need to know where to find it
    Banned
    14962
    Sep 2010
    615
    That is all in the router settings. Every router has different setting screens, so you will have to find the manual for your router.
  1. iOS 4.2 Release Delayed Due To WiFi Issues
    By chisaki in forum iPad General Discussions
    Last Post: 11-14-2010, 08:30 PM
  2. Wifi issues
    By Gringop20 in forum iPad Help
    Last Post: 09-28-2010, 09:51 PM
  3. Wifi Issues Fixed?
    By candafilm in forum iPad General Discussions
    Last Post: 05-30-2010, 12:45 AM
  4. Wil 3G iPads have WiFi issues?
    Last Post: 04-24-2010, 11:27 PM
display wifi password ipad
how to reveal wi-fi password on ipad
how to show wifi password in ipad
how to show wifi password on ipad
ipad reveal wifi password
ipad show wifi password
ipad wifi password show
reveal ipad wifi password
reveal wifi password ipad
show password for wifi on ipad
show wifi password ipad
