WPA2-sensitive connectivity?
This is a discussion on WPA2-sensitive connectivity? within the iPad Help forums, part of the Apple iPad Discussions category; Have a Linksys WRT54G2 wireless router. I have MAC filtered set and that works fine. Whenever I try to use WPA2 for wireless security the ...
Results 1 to 6 of 6
    27241
    Dec 2010
    Atlanta
    10
    Have a Linksys WRT54G2 wireless router. I have MAC filtered set and that works fine. Whenever I try to use WPA2 for wireless security the connection is lost. Simply disabling it restores the connection.
    Ideas? This is for a WiFi-only iPad version that I bought the wife for Xmas.
    iPad Master!
    6869
    4 times
    Jun 2010
    California
    1,278
    After setting the wap2 power cycle the router.. then on the ipad go to the wireless settings and select your network then "forget this network' then reboot ipad and go back into settings to start over with your wifi connection. see if that fixes it up. I use wap2 without issue so it should be doable.
    27241
    Dec 2010
    Atlanta
    10
    I tried this, but it didn't work. I fear the location of my gateway router that hosts the wireless is just in a bad location. My home has the cable Internet coming into the basement and terminates at the cablemodem, which resides in a wiring closet underneath the staircase.
    From there, I branch out using a stock WRT54G2 Linksys/Cisco. The LAN ports afford network branching to the basement and the 1st and 2nd floors. There are then Ethernet switches on those floors to provide tributary networking.
    I thought about buying a WRT54GL, which is a reissue of the original WRT54G running Linux on the Broadcom chipset, but I am not sure how to configure this into the network on the first floor. The gateway router in the basement has a local IP of 192.168.1.1, and the LAN pool is 192.168.1.100 with 50 IPs.
    I tried changing the local IP of the WRT54GL to 192.168.1.2 (to differentiate from the gateway router's 192.168.1.1) but it disallows me from running DHCP on the second router using anything but the 192.168.1.x subnet.
    Anyone know how I should be configuring this second router in the network?
    27241
    Dec 2010
    Atlanta
    10
    Ok, I got the second router integrated into the network on the 1st floor, and WPA2 Personal is enabled, strong signal, etc.
    I only had to shut off DHCP on the second router and insure its local Ip was .2 (naturally).
    iPad Master!
    6869
    4 times
    Jun 2010
    California
    1,278
    So you're up and running! Good job. I'm sure someone will come in the forums and have a similar issue so its great you came back with the answer so we can share!
    27241
    Dec 2010
    Atlanta
    10
    All I did was to change the internal IP address from 192.168.1.1 to 192.168.1.2, and then disable DHCP on the additional router and it worked. The physical connection was LAN port to LAN port.
  1. Replies: 3
    Last Post: 12-29-2010, 11:45 AM
  2. iPad 3.2.1 won't connect to WPA2 WLAN
    By Midnight Blue in forum iPad General Discussions
    Last Post: 09-26-2010, 07:28 AM
  3. Codebook: Keeps Sensitive Material Safe
    By azetetic in forum iPad App Announcements
    Last Post: 09-01-2010, 11:27 AM
  4. Wi-Fi connectivity
    By Russell in forum iPad Help
    Last Post: 08-06-2010, 12:03 PM
  5. Getting WPA2 password to my pad...
    By iSarah in forum iPad Help
    Last Post: 08-04-2010, 11:38 PM
apple wpa2 issues
ipad 2 wpa2 personal
ipad 3 wpa2
ipad wpa2
ipad wpa2 personal
ipad wpa2 problems
macbook pro wpa2 problem
macwpa2wifi
wap2 connection
wpa2 loses connection
wpa2 losing connection
wpa2 mac problems
