After trying upgrade 4.2 wont start
This is a discussion on After trying upgrade 4.2 wont start within the iPad Help forums, part of the Apple iPad Discussions category; After trying to upgrade to 4.2 via itunes it was connected to server and asked me to restore and upgrade.After some time I get a ...
Results 1 to 2 of 2
    26622
    Dec 2010
    After trying to upgrade to 4.2 via itunes it was connected to server and asked me to restore and upgrade.After some time I get a window saying that the computer can be upgraded on 1/102011,an last line saying RESTORE again.Tried again and same thing happens.The Ipad wont start.Tried this procedure on diferent computers,and again the same.pse note on connecting Ipad to Itunes the Serial No and model are not shown,saying not applicable.Is this problem related with drivers?If so how can i find and insert them?
    Please help.
    18578
    9 times
    Oct 2010
    Virginia, usa
    608
    I will assume that you are using Win7.
    Have you tried to uninstall iTunes and re-install it, latest version 10.1.x. If this doesn't fix it, try the plan below. Un-installing should un-install the drivers from Windows and every thing will be ok when you re-install iTunes. However, sometimes, the drivers don't get un-installed properly. So you may have to try the following. Manually un-installing them and let iTunes install them again.
    Go the "START" icon (bottom left corner, blue circle with Microsoft flag on it), in the search box type "Device Manager", select it from the list above. In "Device Manager", look for "Portable Devices", click on it and you should see the "Apple iPad" listed ( with the iPad plugged in ). Right click on that entry and tell it to uninstall, let it finish uninstalling the iPad. Now go down in the "Device Manager" to the entry for "Universal Serial Bus controllers", click on that. Look for "Apple Mobile Device USB Driver", right click on that and tell it to Uninstall. Unplug the iPad and reboot the computer. When it is finished coming up, plug in the iPad, you should see a pop-up on the Task Bar saying that it is installing the device driver for the iPad. If it doesn't you may need to re-install iTunes again, and try again.
    I am also assuming that the drivers are corrupt, because it's not showing the serial number or model number, but seems to know something is plugged in, it just doesn't know what.
    Good Luck
    Pocobear
  1. Photos wont sync ?
    By raisin man in forum iPad General Discussions
    Last Post: 11-28-2011, 02:43 PM
  2. ipad wont cut on!!!!
    By accordlayingkit in forum iPad General Discussions
    Last Post: 12-24-2010, 09:10 PM
  3. ipad wont turn on!
    By jbh19 in forum iPad Help
    Last Post: 11-23-2010, 06:24 PM
  4. Bluetooth wont connect
    By tom1252 in forum iPad General Discussions
    Last Post: 08-12-2010, 06:21 PM
  5. LockDown wont install
    By o_mega05 in forum iPad Hacking
    Last Post: 06-30-2010, 11:58 AM
fore flight wont open on ipad
foreflight won't load on ipod
foreflight won't open
foreflight wont open
ipad device manager
ipad wont turn on after upgrade
ipad wont upgrade to 4.2
why won't foreflight run after attempting update
