Apps not working after update. Help!
This is a discussion on Apps not working after update. Help! within the iPad Help forums, part of the Apple iPad Discussions category; Hey guys, I plugged my iPad into my pc and decided to update to 4.2. After the update, none of my downloaded apps are working. ...
Results 1 to 4 of 4
    27580
    Arlington, TX
    Unhappy Apps not working after update. Help!
    Hey guys,
    I plugged my iPad into my pc and decided to update to 4.2. After the update, none of my downloaded apps are working. When I select it, the screen flashes the app, but then returns back to the home screen. I see them all in the multi-task bar though. What's going on?! Did my iPad never finish updating or syncing? Please help. I've only had my iPad for a day and it's ruining my experience. Thanks.
    -Tommy
    iPad Master!
    6869
    4 times
    Jun 2010
    California
    1,278
    do a power cycle.... turn off ipad by holding the power/sleep button and slide to power off.. If that doesn't work then while the ipad is on hold that same button and hold the home/circle button at the same time until the slide screen comes and goes and the apple logo appears.. if that doesn't work try hooking back up to itunes and doing a restore.
    also check that your apps are updated via the appstore
    19182
    2 times
    Oct 2010
    Israel
    891
    Happened to me too, after the upgrade.
    All you need to do is to re-Sync all your application with the iTune
    Think before you Sync Since you may Sink
    The More Tweaks you have - Less Memory is left
    115833
    Oct 2011
    Hi everyone! I am having the same problem, but i erase one by selecting it for a while until it can move, but i touch the x botton to erase it, and redownloaded and it seems to be solved. I he it works for you too.
  1. Best apps for working with PDF, Excel and Word files?
    By djpritchard in forum iPad Apps
    Last Post: 06-27-2012, 07:00 AM
  2. Replies: 2
    Last Post: 12-25-2010, 11:17 AM
  3. YouTube not working in other apps
    By Phil_Rose in forum iPad Help
    Last Post: 12-22-2010, 09:01 AM
  4. Notifications not working on my apps.........HELP
    By Dukins in forum iPad General Discussions
    Last Post: 12-14-2010, 09:00 PM
  5. Replies: 2
    Last Post: 07-30-2010, 10:10 AM
apple updates are not working on ipad
apps not working after update ipad
apps not working on ipad
games on ipad do not work after updated
ipad 1 apps not working after download
ipad app not working after update
ipad app update not working
ipad apps not working
ipad apps not working after update
ipad apps stop working after update
ipad not working after update
sac bee ipad app stopped working
