connection between ipad and PC works w/ WEP and not w/ WPA2
This is a discussion on connection between ipad and PC works w/ WEP and not w/ WPA2 within the iPad Help forums, part of the Apple iPad Discussions category; hi I'm trying to connect my ipad to my laptop via an ad-hoc connection. (WPA2 - personnal) (bought the ipad today, dl'd the last update) ...
Results 1 to 4 of 4
    26605
    Dec 2010
    toulouse
    hi
    with a WEP key it works perfectly.
    with a WPA2 key it says impossible.
    I've read that WEP keys aren't secure. since I use the ipad (well I'm planning to use, since I cannot connect...) for a professional purpose I don't want to use a connection that can be hacked in minutes.
    what can I do to have it working properly ?
    thanks in advance
    18578
    10 times
    Oct 2010
    Virginia, usa
    608
    Try this, go into SETTINGS - GENERAL - NETWORK, then chose the line with your network name on it and then press the blue arrow on the right, then tap the FORGET THIS NETWORK button at the top of the page. Then setup your network again. OR, you can try to tap RENEW LEASE and see it that helps. The first option above is the best one to try, as it resets everything in the network settings. This worked for me when I had a low signal two foot from the wireless router and could not connect. This will sometimes fix the WEP/WAP problem.
    Good Luck
    Pocobear
    26605
    Dec 2010
    toulouse
    I set up a wpa2 access point on my laptop with connectify
    works perfectly
    iPad Ninja
    5787
    21 times
    Jun 2010
    2,282
    Connectify is a sweet little program for turning a laptop into a wifi hotspot. Recommended here.
  1. Does ipad 3G works in India? Help!! SOS!!
    By bachelor in forum iPad General Discussions
    Last Post: 06-15-2011, 02:24 PM
  2. iPad 3.2.1 won't connect to WPA2 WLAN
    By Midnight Blue in forum iPad General Discussions
    Last Post: 09-26-2010, 07:28 AM
  3. Replies: 3
  4. Ipad 3g 3.2.1 jailbreak now works!
    By Timmah in forum iPad Hacking
    Last Post: 08-07-2010, 01:09 PM
  5. Getting WPA2 password to my pad...
    By iSarah in forum iPad Help
    Last Post: 08-04-2010, 11:38 PM
ad hoc network between pc and ipad
connectify
connectify for ipad 2
connectify ipad 2
connectify ipad2 connecting
connectify ipod wont connect
connectify not showing wpa2
how to use ipad on wpa2 ad hoc
ipad cannot connect connectify
ipad cannot connect to connectify
ipad1 wont join adhock network?
iphone ad hoc works with wep but not wpa2
Tags for this Thread
