autocorrect 'x' not working
This is a discussion on autocorrect 'x' not working within the iPad Help forums, part of the Apple iPad Discussions category; I've had my iPad for about three months now. A few weeks ago the 'x' next to the autocorrect bubble quit working. No matter where ...
Results 1 to 10 of 11
    26297
    Dec 2010
    Usa
    I've had my iPad for about three months now. A few weeks ago the 'x' next to the autocorrect bubble quit working. No matter where I touch on the screen, including the 'x', the autocorrect suggestion is chosen. I've turned the device off and then on, reset the user dictionary, checked to make sure the screen is calibrated, etc. No luck. I don't mind autocorrect, but I need the option to reject suggestions. Any ideas?
    18578
    9 times
    Oct 2010
    Virginia, usa
    608
    This won't help with the lost x, but you can disable auto-correct in Settings > General > Keyboard > Auto-Correction. I disable as it causes more problems than it worth, with it's predictions of what I want to say. It comes up with some of the stupidest things, totally changes what I wanted to say. Not to mention is slows down your typing.
    Good Luck
    Pocobear
    iPad Guru
    1284
    7 times
    Mar 2010
    2,623
    You should just be able to tap the autocorrect suggested word to disregard it.
    26297
    Dec 2010
    Usa
    Thanks, but tapping on the suggested word, the 'x', and anywhere else on the screen results in the suggested word being inserted. Just restored the ipad and then installed a back up. Still the same problem. Wondering if there is a software issue.
    iPad Guru
    1284
    7 times
    Mar 2010
    2,623
    Works fine on mine. It only uses the suggestion if I tap space or anywhere on the screen that isnt the suggested word.
    13653
    Aug 2010
    Portugal
    15
    I have the same problem! Did you find any solution?
    42056
    Texas
    192
    If it's only been 3 months, I say take back to apple store and see if they can fix it.
    13653
    Aug 2010
    Portugal
    15
    fix what? lol
    if it is not general it isn't neither a bug in sw or hardware so maybe that's a version problem...
    42056
    Texas
    192
    Quote Originally Posted by 0biwan
    fix what? lol
    It's most likely a software problem. Things like this can happen, but usually it happens to windows. However, you might be able to fix it if you do a full restore but don't do the backup restore, as whatever setting was messed up could be put back on your device. You'd have to set it up as new and see what happens.
    iPad Addict
    37720
    6 times
    Colonial Heights,Va
    1,395
    I've found it only happens on a few apps on mine. Diary XL being one of them. I don't remember any others off the top of my head but since I just used that one it came to mind. 99% of my X tapping works fine but those it doesn't work on I just press until the magnifier comes up and correct it.
    Support Our Troops!!
    This post was Tapatalk approved. Sent from my Incpad
  1. new ipad not working
    By shylah in forum New Member Introductions - Site Assistance
    Last Post: 12-25-2010, 02:28 PM
  2. Can't have spell check without autocorrect
    By dragon499 in forum iPad OS
    Last Post: 12-12-2010, 10:33 AM
  3. 3G Not Working
    By cherhall in forum iPad Help
    Last Post: 11-24-2010, 01:45 PM
  4. Working Mac osx theme?
    By rotaz in forum iPad Hacking
    Last Post: 10-17-2010, 05:04 PM
  5. My 3G isn't working...
    By Blind in forum iPad Help
    Last Post: 06-20-2010, 08:53 PM
how to ignore ipad autocorrect
how to reject autocorrect on ipad
ignore autocorrect ipad
ipad autocorrect reject
ipad help
iphone autocorrect ignore
iphone autocorrect not working
reject spelling suggestion ipad
