When I go to the app store and search for apps under categories it only shows the first page of app and I can't go to the second page or any other page. The arrow to go to next page is just gray like it is inscribe, what is wrong???
I have another problem. I can't download AppStore with age limit 12+. Pretty annoying. I also have a problem with Tap Tap Radiation. The download button have turned to installed. The app is not installed on my iPad. Please help me.
Ok. I found the problem. The restrictions is on, but the restrictions page is coded. I haven't set any code on it. Please help me!
I guess you've probably solved this problem now, but - just in case....
Some categories only have a single page of apps, so the 'next page' button is always gray.
You need to wait for the app icons to download before the button becomes active.
Other than that, I can't see what the problem would be.
Hope you manage to fix it...
I waited 20 minutes for next page arrow to turn. It never did. The page says 5000 apps. Can anybody help?![]()
Been having the same issue...must be a problem with the store....
Yeah, I have the same problem. It only seems to be when I'm searching through using the categories option.
The little arrow never goes grey, even after 20mins waiting.
The UK appstore is working fine.
If a reboot doesn't fix the problem, there isn't much one can do, except to wait for Apple to fix it.
I've rebooted (held home and power button until the apple logo comes up) twice now, and it still isn't working. Should I try by turning the iPad off and then back on? Would that make any difference?
I'm having the same problem but just noticed it as of March 5th, in the AM. I no longer can just view the different categories. It takes me right to the Search apps page. That would be ok but you can only select one filter to search. And then if you want to just view them all, it only shows the first page like others have reported. I don't think its my iPad but rather Apple.
Karen
