Charging
This is a discussion on Charging within the iPad Help forums, part of the Apple iPad Discussions category; When the iPad is on charge it automatically switches on, does it have to be on to charge it or can you switch it off. ...
Results 1 to 4 of 4
Thread: Charging
    24125
    Dec 2010
    North Berwick, Scotland
    98
    Charging
    If you can switch it off how do you know it's fully charged as there's no lights to show it's even charging
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    I haven't tried this with the latest iOS 4.2.1, but it used to be that if your charge level was below 20%, you could not turn off your iPad. As soon as you do, it will just come right back on. If it is over 20%, then you can turn it off.
    So how do you know when it is charged if it is turned off? You don't!
    24125
    Dec 2010
    98
    Thanks c4 seems strange there's no light indicator
    18578
    10 times
    Oct 2010
    Virginia, usa
    608
    There's an app called BatteryDoctor that will help charge the iPad and will make a noise and tell you to unplug the iPad when it's done charging. I will also show you how long it will take and the approximate times to use different things, such as videos or music at the current charge level.
    Good Luck
    Pocobear
  1. Charging
    By Hawkmech in forum iPad General Discussions
    Last Post: 08-12-2010, 09:54 AM
  2. USB Charging.......AHAAHHHHHHHHH!
    By windycitycouple in forum iPad Help
    Last Post: 08-01-2010, 03:03 PM
  3. Charging?
    By HUNTER1 in forum iPad General Discussions
    Last Post: 07-26-2010, 10:57 PM
  4. Charging while using
    By Sayishere in forum iPad General Discussions
    Last Post: 07-25-2010, 06:31 PM
  5. Charging???
    By HarlyFan in forum iPad Help
    Last Post: 07-12-2010, 08:51 AM
does the ipad have an automatic shut off when charge is done?
how to turn off charging sound ipod
ipad 3 charging turn off automatically when fully charged?
ipad app that makes a sound when fully charged
ipod touch no sound when charging
no ipad charging light
no sound on ipad when charging
no sound on ipod touch when charging
no sound when charging iphone
no sound while charging iphone
should i turn i-pad mini on when charging ?
turn off sound when charging iphone
