Camera not supported
This is a discussion on Camera not supported within the iPad Help forums, part of the Apple iPad Discussions category; New ipad and went to connect my Canon EOS 300D camera - purchased in 2004 and have the message 'cannot use device - the connected ...
Results 1 to 4 of 4
    25206
    Dec 2010
    Eden Australia
    New ipad and went to connect my Canon EOS 300D camera - purchased in 2004 and have the message 'cannot use device - the connected USB device is not supported. Always works fine on my mac computers. Any ideas as one reason for purchasing the ipad was to download photos to. Thankyou
    14699
    12 times
    Sep 2010
    Woodlands MB, Canada
    349
    If your camera menu has a 'Communication' setting, make sure you have PTP selected and not 'Normal'. I'm not sure this will work.. It's just a suggestion.
    "Normal" is Canon's proprietary communication protocol. It's used by applications developed by Canon.. (The ones that came on the CD included with the camera).. The iPad won't be able to recognize Canon's proprietary mode..
    "PTP", stands for Picture Transfer Protocol. It's a universal communication mode used by all the digital camera makers. The iPad should recognize this.
    With early EOS cameras, you had to manually switch between the two using the camera menu... With the newer models, they autodetect what protocol the host device wants to use and do the switching for you.
    25206
    Dec 2010
    Eden Australia
    Camera not supported thankyou
    Thankyou so much jwt873. It worked. Changed the communication setting and the ipad is downloading photos as I speak. Greatly appreciate your support. Best wished for 2011. Cheers Deb
    14699
    12 times
    Sep 2010
    349
    Great.. Glad to hear it worked... If you find you're having trouble now using your Canon supplied apps (like Zoombrowser etc), you'll have to change the Communication back to 'Normal'.
    And a Happy New Year to you to
  1. Mp3 not supported.
    By matt_90036 in forum iPad General Discussions
    Last Post: 11-22-2010, 03:16 PM
  2. Digtal camera who makes a good camera
    By henry2 in forum Off-Topic
    Last Post: 04-07-2010, 08:15 PM
cannot use device
canon 350d ipad
connect canon rebel 350d to ipad
connect eos 300d to ipad
download photos from canon eos to ipad
downloading 300d canon to ipad
eos 300d to ipad
ipad canon 350d
ipad the connected usb device is not supported
the connected usb device is not supported ipad
usb device not supported ipad
