Results 1 to 10 of 13
Like Tree1Likes
Thread: Ipad stuck in restore unknown error 1611
    25518
    Dec 2010
    Hi,
    I'm getting pretty desperate. Got a used ipad, the user reset it to remove his data. Ipad was signalling that it needed to connect to itunes.
    Hooked it up to itunes, which wanted to update the software. This failed and put the unit in restore mode. I have followed every procedure on the apple site, no result. Sometimes:
    iTunes could not conect to this iPhone because an unknown error occurred (0xE8000065) before the 1611 error
    always followed by:
    The iPad "iPad" could not be resored. An unknown error occurred (1611)
    Installed a clean windows 7 64bit on my computer. Updated it and installed itunes. Same problem. Itunes downloads the software, prepares the ipad for a restore. On the ipad an apple logo with a progress bar appears, but than it stops.
    Any ideas how to get out of this mess. My next step would be to use another computer, but I don't have one. I'm about ready to send it off to apple for repair, but maybe there are some other tricks to try.
    Regards,
    Frank
    iPad Enthusiast!
    24657
    Dec 2010
    Home
    53
    Try and use another computer, i was in the same boat and i tried another laptop and bam it worked, gppd luck
    25518
    Dec 2010
    Quote Originally Posted by Walker View Post
    I'll try to find another computer. I think it has to do with the power level of the usb. In the meantime I recovered the ipad using bootrec.
    thanks for the tip
    33650
    Feb 2011
    netherlands
    Help
    mine is stuck at the end off the restoring bar , and now i did a reboot of device .. and when i try it again is does it again , so i think i have the same problem as u .. BUT when i use recboot It wil try to kick it out , but then it wil get right back into recovery and do this untill u close the program
    111245
    Oct 2011
    Tempe, AZ
    I had the same error used my laptop to get my ipad back to default. It has updated the OS. Now how would I get it to sync my music, movies, photos on the original pc. The laptop doesn't have my music, movies and photos installed. The first time i tried to sync Itunes on my original pc it stated it was still in recovery mode and brought the same issue (Error 1611). How can I clear that error so I can re synch my data? Any Ideas? Appreeciate any help.
    124693
    Nov 2011
    Provo UT
    It's the power
    Walker nailed it - it's to do with the power. I got the error on my brand-new iPad2, after reading this thread I moved the USB from my monitor to the USB port on the laptop and the restore worked.
    tasher likes this.
    130306
    Dec 2011
    United States
    Confirmed Fix for Error 1611 -- Power Issue
    BINGO! It's a power issue. I got the error trying to upgrade to iOS 5 with the iPad connected to a USB port on my monitor...where I had been successfully sync-ing for quite some time. Tried everything to no avail. Went to another computer and had the same problem (however I was plugged into a USB port on the monitor of that computer too but hadn't yet realized my error). After reading this post, I plugged into a USB port on the CPU itself on the same computer and bam, it worked immediately. Apparently there's enough power to sync from a USB hub (like on a monitor) but not to do a restore or software update. Thanks guys! THIS SHOULD BE ON THE APPLE WEBSITE HELP FILE BUT IS NOT. I even called Apple tech support and they didn't know about this.
    131299
    Dec 2011
    Louisville, KY
    Ditto on the above. Had the usb plugged into a monitor port. Previous sync events ok except got the note that the iPad was not charging. This crash occurred during the os update. On line with apple support who has been very patient while the iPad is going through the restore process and is insistent on staying with me until the iPad is completely restored. Passed on this information to the tech who is passing same on to the senior advisor. Hopefully the word will get out.
    141894
    Dec 2011
    Geniuses. My iPad bricked itself while attempting to do an update over wifi sync when powered through a home theater receiver. It failed. I then tried to recover the iPad, but kept getting the 1611 error. I had the iPad connected to the USB port on my laptop docking station, but it kept failing with the restore. I then connected it to a powered USB hub and it has just finished restoring.
    152878
    Jan 2012
    DE, USA
    I bought an Apple certified refurbished iPad2 for my birthday, and it just now bricked during iOS5 update. Thought I had gotten a dud or something and was ready to punch a hole in the wall lol. Thanks to you guys, I changed USB ports from my monitor to the mobo and it worked. Man...that was unnecessarily stressful. My iPad is still restoring, but it's no longer in 1611 hell anymore.
    Thanks again!
  1. Ipad stuck in restore mode
    By Yodale in forum iPad General Discussions
    Last Post: 09-16-2011, 03:44 PM
  2. Unknown text messages
    By rykk in forum iPad Help
    Last Post: 10-24-2010, 05:13 PM
  3. Restore didn't restore?
    By Todd M in forum iPad Hacking
    Last Post: 10-12-2010, 06:47 AM
  4. iPad stuck in DFU mode & restore failing.
    By Phant0m_ in forum iPad Hacking
    Last Post: 10-11-2010, 09:25 PM
  5. restore ipad from shsh or regular restore+jailbreak
    By bdaddy in forum iPad Hacking
    Last Post: 07-12-2010, 04:55 PM
ipad 1611
ipad could not be restored 1611
ipad could not be restored error 1611
ipad error 1611
ipad error 1611 fix
ipad restore error 1611
ipad unknown error 1611
the ipad could not be restored 1611
the ipad could not be restored an unknown error occurred 1611
the ipad ipad could not be restored. an unknown error occurred (1611)
the ipad ipad could not be restored. an unknown error occurred 1611
