Need Help on Updating the OS
This is a discussion on Need Help on Updating the OS within the iPad Help forums, part of the Apple iPad Discussions category; I am still running OS 3.2 and would like to upgrade to the current OS, but I am not sure how to do this. My ...
Results 1 to 3 of 3
    4772
    May 2010
    12
    My iPad was set up on my Windows pc, and synced to my iTunes account on that computer. I no longer have access to that computer at this time (but I will, eventually...)
    I am looking for suggestions on how I can update the OS without that pc. Can I bring it to the apple store, even though it was set up (formatted??) on a Windows pc?
    The other option is that I know my sister has a Mac, and has never even set up an iTunes account on it. Hard to believe, I know! Can I use her Mac to update my Windows-ish iPad, and if so, what about all my data? I don't want her Mac to be my primary library, and I don't want all my apps to be erased. I am confused about all this and appreciate any advice. Thanks.
    17419
    2 times
    Oct 2010
    Texas
    646
    You can update with any computer without syncing or deleting data... But I would recommend having a backup.... You never know what might happen during an update.
    Everything is Bigger in TEXAS!!
    iPad 16GB WiFi
    iPhone4 32GB
    Be sure and check out iphone4forum.net! For anything iPhone..
    Me over on the other side...
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    The easiest thing to do would be to being it an Apple store... if you can get an appointment with a "genius". It doesn't matter what type of computer you use to sync your iPad with.
  1. I'm not updating to 4.2.....
    By iFreeman in forum iPad OS
    Last Post: 01-06-2011, 07:31 PM
  2. Apps updating to use multitasking
    By BrennB in forum iPad General Discussions
    Last Post: 12-05-2010, 05:10 PM
  3. need help updating iPad
    By locus in forum iPad Hacking
    Last Post: 11-24-2010, 05:42 PM
  4. Updating apps are all stuck!
    By SweetPoison in forum iPad Help
    Last Post: 10-29-2010, 07:11 PM
  5. updating app on cydia...
    By ipadmania in forum iPad Hacking
    Last Post: 07-14-2010, 01:11 PM
do i need to run os updates for my ipad
update ipad operating system without computer
update ipad os without computer
update os for i pad
what operating system am i running for ipad
what os am i running in my ipad
what os am i running on my ipad
what os am i using on ipad
