Weird thing
This is a discussion on Weird thing within the iPad Help forums, part of the Apple iPad Discussions category; My iPad was charged to 8% - meaning the battery was almost dying, but I wanted to sync it real quick and connected it to ...
Results 1 to 6 of 6
Thread: Weird thing
    24041
    Dec 2010
    Weird thing
    My iPad was charged to 8% - meaning the battery was almost dying, but I wanted to sync it real quick and connected it to my laptop. Of course the not charging msg came up. After about 5 hours, despite 'not charging' I disconnected it and the battery's at 41% right now. Is that normal?
    17954
    3 times
    Oct 2010
    N.E. Ohio
    878
    One of the things I noticed that iPad doesn't do is charge via USB to my iMac like both my Blackberry and Droid do. So no, it's not normal I don't know how to explain that.
    18578
    9 times
    Oct 2010
    Virginia, usa
    608
    Sorry, Hook, but that is very normal. It is charging, just slowly, should be about 75% slower, but, it seems to be only about 50% slower time wise. Normal charge starts out at about 2amps and ramps slowly down to a trickle over time. With USB it starts out about 0.5amps ( 500milli amps) and takes longer, but it will charge it to 100% overnight. I do it all the time, seldom use the iPad charger, except for the once a month less than 20% to 100% charge.
    Good Luck
    Pocobear
    3319
    3 times
    Apr 2010
    399
    Apple state that charging via USB nay occurs with "newer" Macs. That's why the adapter that comes with it is a wall charger.
    I've noticed that mine does charge VERY slowly on my PC, since it only takes a couple of hours for an 80% charge on the wall, and I get 10-12 hours per charge, it doesn't matter much.
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,239
    They should change that message from Not Charging to Charging, but not real fast!
    The thing you have to be careful of when you hook your iPad up to a PC or laptop is that if your power saver mode puts your computer to sleep or into hibernation mode, it will stop charging and could even possibly start depelting your battery.
    iPad Junkie!
    22282
    Nov 2010
    Kentucky, USA
    142
    I think I'll try syncing and charging at the same time. Sounds good to me!
  1. Weird auto-correction
    By tosh.jc in forum iPad General Discussions
    Last Post: 09-27-2010, 10:35 AM
  2. Jailbreakme.com 3.2.1 Weird problem
    By spiderguy84 in forum iPad Hacking
    Last Post: 08-07-2010, 03:02 AM
  3. Weird request
    By jenna in forum iPad General Discussions
    Last Post: 05-15-2010, 04:31 PM
  4. This is weird
    By Sincere11105 in forum iBooks
    Last Post: 04-24-2010, 08:22 AM
  5. Tree frog pad is weird
    By ryan8813 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 04-13-2010, 11:01 AM
weird thing on ipad
weird things for ipads
weird things that charge a ipad1
weirld stuff ipads can do
