IPAD w/Remote app questions/help
This is a discussion on IPAD w/Remote app questions/help within the iPad Help forums, part of the Apple iPad Discussions category; Hello all, Have two questions regarding using the Apple Remote App on the IPAD. 1) When I first set it up and was remote controlling ...
Results 1 to 2 of 2
    23576
    Dec 2010
    Hello all,
    1) When I first set it up and was remote controlling Itunes on my music server the Now playing Album Cover view screen the transport/remote controls were larger buttons at the bottom. Now the controls have gotten to the top and are smaller. I have old eyes and prefer the larger buttons at the bottom. Any advice on how to get this back ?
    2) Also when using remote to control Itunes from my server, when I switch from one album to the next album, the now playing album cover view screen will still show the previous cover. The only way I have found to alleviate this is to go to the remote settings screen and re-select the appropriate library, come back to Now Playing Album cover screen and it will be correct.
    Thank you in advance for any help and much love, joy, and music this holiday season.
    Common in NY
    18578
    10 times
    Oct 2010
    Virginia, usa
    608
    I tried several things and couldn't find any way to make the controls bigger. I do like the way it displays so much more now. If you tap once on the Now playing screen. the controls will appear at the top, the same size, but white on black, might be easier to read that way.
    I tried to manually switch between several albums while it was playing and the album art followed the album on the now playing screen. If that's your problem, close all apps and do a reset of the iPad, hold the SLEEP (top) and HOME (lower front) buttons down together for about 10 seconds, until you see the Apple icon, release buttons and wait for it to reboot. This can take a few minutes, just wait it out.
    Try again, if it still does it, let me know and tell me exactly what you do to get that symptom. I'll try to see if I can duplicate it.
    Good Luck
    Pocobear
  1. iPad/iPhone Remote
    By naarkrog in forum iPad Apps
    Last Post: 11-30-2010, 05:24 PM
  2. Remote iPad user !
    By iPad-Sweden in forum Off-Topic
    Last Post: 10-21-2010, 01:50 AM
  3. What is the best remote desktop for iPad?
    By MobileSpoon in forum iPad General Discussions
    Last Post: 10-02-2010, 06:47 PM
  4. iPad as a remote
    By mm5300 in forum iPad Apps
    Last Post: 07-02-2010, 04:32 PM
anleitung apple remote-app
apple remote app for ipad hangs
apple remote app instructions
apple remote app manual
how to reset remote app on the ipad
ipad app remote user guide
ipad remote app reset
ipad remote app resetting
ipad remote support app
ipad reset remote app
remote app for ipad faq
remote app for ipad manual
