Charging generates heat
This is a discussion on Charging generates heat within the iPad Help forums, part of the Apple iPad Discussions category; When I charge my iPad with the cords, the little whie box between the two cords becomes so hot it will burn me. Does this ...
Results 1 to 6 of 6
    iPad Junkie!
    22282
    Nov 2010
    Kentucky, USA
    142
    When I charge my iPad with the cords, the little whie box between the two cords becomes so hot it will burn me. Does this happen to anyone else? Should I be worried? Is this normal?
    17419
    2 times
    Oct 2010
    Texas
    646
    What charger are you using? If its the apple one sounds like you should get it replaced.
    Everything is Bigger in TEXAS!!
    iPad 16GB WiFi
    iPhone4 32GB
    Be sure and check out iphone4forum.net! For anything iPhone..
    Me over on the other side...
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,239
    It is absolutely NOT normal! I let my iPad drain completely today and it has been on the charger for several hours now and the charger is only slightly above room temperature.
    Banned
    428
    2 times
    Feb 2010
    Japan and Seattle
    1,131
    Mine gets hot, but not to the point that it will burn skin. When you say "it will burn me" are you just saying it's hot, or will it actually BURN your finger?
    iPad Junkie!
    22282
    Nov 2010
    Kentucky, USA
    142
    It won't make a blister, but it definitely is painful. I'll just try to get a replacement.
    iPad Junkie!
    22282
    Nov 2010
    Kentucky, USA
    142
    Quote Originally Posted by Dannyboy85 View Post
    It's the whiter cord (2 parts) that came with the device.
  1. Charging
    By Hawkmech in forum iPad General Discussions
    Last Post: 08-12-2010, 09:54 AM
  2. Ipad shuts down in heat lawsuit.
    By Jazzephaye in forum iPad General Discussions
    Last Post: 08-10-2010, 03:35 PM
  3. Charging?
    By HUNTER1 in forum iPad General Discussions
    Last Post: 07-26-2010, 10:57 PM
  4. Charging while using
    By Sayishere in forum iPad General Discussions
    Last Post: 07-25-2010, 06:31 PM
  5. Charging???
    By HarlyFan in forum iPad Help
    Last Post: 07-12-2010, 08:51 AM
burning hot
charger hot while charging ipad
heat from ipad charger
ipad charger burn
ipad charger heat
ipad charger overheating
ipad charger plug heat
ipad charger temperature
ipad cord over heating
ipad power cord over heating
is it normal for the ipad power cord to be so hot
is it okay when the chargee of ipad is heating
