Results 1 to 9 of 9
    12657
    4 times
    Aug 2010
    Area DM51
    669
    Exclamation ** FIXED! ** iPad seems totally dead - please HELP !!!
    Aaaaargh!
    My iPad has died!
    None of the buttons make any difference, no sound, no display, plugging into charger makes no difference, connecting to computer doesn't register on iTunes, NOTHING WORKS!!!
    If this is a clue to what is wrong, I had left it running a pdf file in Goodreader - I just didn't switch it off after reading it, as I was busy with something else. I assumed it would power off if it needed to.
    Helppppp!!
    2016
    Apr 2010
    Cardiff
    62
    Don't panic
    I had that a few months back, very similar circumstances not good reader but running something else. I think I did a hard reset, hold home and power together and it will eventually reboot. No issues since
    12657
    4 times
    Aug 2010
    Area DM51
    669
    Thnaks!!
    I'll try that - VMT!
    12657
    4 times
    Aug 2010
    Area DM51
    669
    It worked!
    It worked! Back on as if nothing had happened. Can't thank you enough for your super-speedy response - I owe you a large beer !
    Now I better go and change my panic-stricken sigline, LOL
    2016
    Apr 2010
    Cardiff
    62
    Lager,bitter,White wine but definitely not Red
    Glad sorted.
    21975
    Nov 2010
    North Alabama
    6
    Unhappy mine died, too!
    Quote Originally Posted by DM51 View Post
    Aaaaargh!
    My iPad has died!
    Helppppp!!
    This morning, while running Pulse newsreader, I laid it down to answer the phone. Two minutes later when I picked it up, the screen was blank and it would not respond to any button presses. drawing on the old iPaq habits, I held down the Home and Sleep keys and it came back up the out-of-the-box iTunes connection screen. had to restore from ground zero. I lost some apps that I had added since last sync (which was at the 4.2.1 update). I hope this is not a recurring problem. I have since seen several posts with similar issues. Again I am reminded that I should have waited on the Android tablets.
    iPad Ninja
    3495
    27 times
    May 2010
    Switzerland
    2,017
    I also just had this happen yesterday (Friday). Frustrating and scary, but it happened once before too, so I knew what to do.
    To be honest, I was also using GoodReader heavily at the time, and doing something funny with rotation and safari when it went dead.
    12657
    4 times
    Aug 2010
    Area DM51
    669
    Thanks to all! It was quite worrying, and of course I couldn't get at the iPad user guide or help to find out how to deal with it.
    Numblock, I just filed a report on post #1 to ask for the thread title to be changed. I tried editing post #1 in advanced mode, but the title has stayed the same.
    12328
    Aug 2010
    Markdale, Ontario
    571
    The link here seems to be Goodreader. Would recommend that you remove the app and notify the creators of Goodreader and tell them what happened.
    I never give up. Snideness and rudeness of any sort WILL be returned in kind.
  1. My iPad seems to be dead!
    By hotu matua in forum iPad General Discussions
    Last Post: 02-09-2011, 08:18 PM
  2. Dead iPad, support abroad
    By silvert in forum iPad Help
    Last Post: 09-19-2010, 02:35 AM
  3. Dead iPad
    By woodturner in forum iPad Help
    Last Post: 09-11-2010, 11:42 AM
  4. Dead ipad?
    By Mmark in forum iPad Help
    Last Post: 07-24-2010, 11:17 PM
  5. Ipad initial set up after unboxing-is it dead?PLEASE HELP
    By mr848 in forum iPad General Discussions
    Last Post: 07-03-2010, 07:44 PM
completely dead ipad
ipad 1 completely dead
ipad completely dead
ipad dead no power
ipad has no power
ipad is totally dead
ipad no power
ipad seems dead
ipad totally dead
ipadtotallyoutofpower
my ipad is totally dead
totally dead ipad
