Results 1 to 4 of 4
    22632
    Nov 2010
    Seaham, County Durham. UK
    Adobe Flash and Work arounds
    Before i bought my ipad i was aware apple and adobe flash dont work, i still bought it as i am starting to be an apple convert.
    Is there any sort of work around of plug in that can be installed to overcome the flash issue to enable sites to work.
    Any help is appreciated.
    Si
    Banned
    14962
    Sep 2010
    Louisville, KY - USA
    615
    As it stands in iOS, no. There is a browser that precaches some flash sites and allows them to be viewed. There was/is a browser for the iPhone (that works on iPad, but small...) that would allow SOME sites to be viewed, however there is not an iPad version. The name escapes me, however. I am sure someone will know it off the top.
    You can jailbreak the iPad and install work-a-rounds that way, however as I have not, and will not, jailbreak, I cannot give you any tips on how.
    22633
    Nov 2010
    Illinois/USA
    6
    I have an app called Skyfire that I bought from the apps store.
    I wanted to be able to watch tv shows from the nbc, fox, and cbs websites and found out I couldn't because the ipad wouldn't use flash. With this app I can now do that. It is like a little browser and works great. Can now watch videos that I couldn't before. Check it out and it is well worth the money. I can also stream live nba, ncaa football and basketball games. The bigger the picture you make it does get a little blurry but still is worth it to be able to watch the games.
    Banned
    14962
    Sep 2010
    615
    Thanks for the name, I forgot it.
    The thing is, it is an iPhone app that will run on the iPad, but not in full screen mode. It will not run ALL flash, only certain ones.
    Personally, until they have an iPad version and a "lite" version to try before buy, I won't be getting it.
  1. Can't download adobe flash player to ipad
    By Wwbruins in forum iPad FAQ
    Last Post: 06-26-2012, 09:31 PM
  2. Adobe flash
    By Astachloe in forum iPad Development
    Last Post: 08-11-2010, 05:04 PM
  3. Adobe FLash
    By lebob2 in forum iPad Help
    Last Post: 06-10-2010, 03:24 AM
  4. Clientless Adobe Flash For The iPad
    Last Post: 04-14-2010, 07:52 AM
adobe flash work around ipad
app to get around adobe flash
app to get around flash player
bypass flash player ipad
does adobe flash work on ipad
does adobe work on ipad
flash on ipad workaround
getting flash to work on ipad
how to bypass flash player on ipad
how to get around flash player on ipad
ipad flash player workaround
ipad flash work around
