Results 1 to 10 of 13
    22613
    Nov 2010
    Ipad does not wake from sleep mode
    I have some trouble with an iPad 3G with OS 4.2.
    Every time I put it in sleep mode, or if the iPad autolocks and it sleeps for more than 60 seconds or so, I am unable to wake it up using the Sleep/Wakeup button. The only way I can wake it up is by doing a reboot (home+sleep).
    This only happens when the iPad is not connected to a power supply, if it is connected everything works.
    This makes me suspect that something goes awry when it goes into "deep sleep" to save power and dumps RAM to disk... or alternatively when it restores RAM from disk.
    I have tried restoring the device through iTunes but that didn't fix the issues.
    Has anyone had a similar issue? Do you have any idea on how to fix it? The iPad was bought abroad, so I think my warranty options are limited.
    iPad Ninja
    3495
    27 times
    May 2010
    Switzerland
    2,017
    Have you given it a good charge? That sounds like what happens when the battery is empty.
    22613
    Nov 2010
    Yes, I get this behavior even with a full charge.
    44301
    5
    Ipad wont wake up when in sleep mode?
    Hi everyone,
    Sorry if this a old question, ive been trying to find some information on this problem but not been having much luck.
    Basically I received my "Manufacture Referb" iPad 32GB WIFI yesterday, it is great, looks brand new and got it for a fraction of the original price. However I have noticed one annoying thing which I'm 99.9% sure shouldn't be happening.
    I have updated the iPad to the latest version 4.3.1, installed several apps and set up the WIFI and email accounts etc. It wasn't until later on in the evening when my girlfriend managed to prize it from my hands that I found out the following.
    If the iPad automatically goes into sleep mode or I purposely put into sleep mode and don't touch it for say 5 minuets or so I won't respond when I try and wake it up. I've tried with both the wake/sleep button and the home button but no response. The only way to wake the iPad back up again is to do a reboot holding the sleep/wake and the home buttons together for 10 seconds.
    The battery is almost fully charged and I can't understand why this is happening, the is a lot of chatter about this problem online but nothing definitive or any info from people whom have had this problem and how this was fixed.
    I have got a 90 day warranty on it but just wanna see if if this is a known problem with a easy fix?
    Any solutions and advice would be greatly appreciated.
    Regards,
    Joe
    116 times
    15,249
    What happens if, rather than putting it into Sleep mode, you turn it off by simply holding down only the Power button for a couple of seconds and then sliding the control to accept the offer to switch off? When it's powered down completely, will it then turn on when you press and hold the Power button only again?
    This might help isolate where the problem lies.
    44301
    5
    Hi Tim,
    If I actually turn the iPad off like you describe above it is fine, I can turn it back on again by holding the on/off or sleep/wake button for 2 or 3 seconds. In fact this is what I've been doing so that I don't have to keep rebooting it.
    I have also tried, as suggested from info online to restore the iPad through iTunes. However when I try it gives me and error code of 1602 when trying to do this, I believe this is possibly due to some corrupt data for iTunes and/or a corrupt registry file. It suggests removing iTunes from the computer and reinstalling iTunes again but i wanted to see if there was a known fix before I try this.
    Also if I was to uninstall iTunes and then reinstall would I loose my apps etc or are they automatically stored in a safe folder?.
    Regards,
    Joe
    44301
    5
    Same Problem?
    Hi mate, I can see this was posted a while ago but did you ever fix the problem.
    I'm also experiencing it, i have rebooted and restored trough iTunes but when the iPad goes to sleep for more than a few minuets it wont wake up and i have to reboot to turn on???
    Regards
    Joe
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    I had a long thing written out, but accidentally click one of the many advertisements that fill these forums and it was all lost. Im not typing it all up again.
    go to apple store, they will replace it.
    22613
    Nov 2010
    Joey: As Mikes said -- I went to the Apple store, and after trying the obvious things (reboot etc) they replaced it.
    116 times
    15,249
    Quote Originally Posted by JoeyFizzle View Post
    Hi Tim,
    Regards,
    Joe
    OK - I'm not sure on this one. I'm hoping someone else in the Forum can answer this. I'd be careful and wait until you get a credible answer. Apps you can download again without charge, but Movies and Music you'd be charged again if you lost them.
    Be careful....let's wait a while and see what anyone suggests. I don't want to advise you and then you lose everything....
  1. How To: Put your iPad into Recovery Mode
    By mk1151 in forum iPad Help
    Last Post: 12-05-2012, 07:23 AM
  2. Sleep mode question ~
    Last Post: 03-07-2012, 04:07 AM
  3. Dropped, dented and sleep/wake barely works.
    By Sfoanna in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 09-08-2010, 02:57 AM
  4. Flower icon @ ipad wake up screen
    By paulyeo11 in forum iPad General Discussions
    Last Post: 08-22-2010, 11:53 PM
  5. Why do they call it the Sleep/Wake button?
    By iPadCharlie in forum iPad General Discussions
    Last Post: 08-07-2010, 03:31 PM
how do i get my ipad out of sleep mode
how to get ipad out of sleep mode
how to wake up an ipad
how to wake up ipad
how to wake up my ipad
how to wake your ipad from sleep mode
ipad 2 3g is not waking up
ipad 2 not waking up
ipad 2 won't wake up
ipad not waking up
ipad will not wake up
ipad2 won't wake up
