Photos - fix for rotation issues (landscape vs. portrait)
This is a discussion on Photos - fix for rotation issues (landscape vs. portrait) within the iPad Help forums, part of the Apple iPad Discussions category; I found a temporary fix: Take your screenshot in landscape. Use the free app called "PhotoPad" to rotate it. Then it ends up back in ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    2119
    Apr 2010
    Utah
    5
    Temporary fix
    Then it ends up back in your photo app in the orientation that you want.
  3. #12
    29485
    Dubai
    Thumbs up PhotoPad fix
    This fix works perfectly and is permanent if you delete the original.
    I create paintings with the Brush app and it does not always save the orientation desired, PhotoPad is the answer, thank you!
  4. #13
    57053
    May 2011
    Netherlands
    5
    The only problem is that the saved image has way more compression than the original... Is there any other app that saves better versions ?
    EDIT: I found that the App "Rotate and Crop" uses way less compression, leaving the picture quality intact.
  5. #14
    61788
    Jun 2011
    USA
    32
    Quote Originally Posted by wot_fan
    I agree, it is a bug. When find I stuff like this I go here and report it.
    Apple - Feedback
    I have already reported this issue but it wouldn't hurt if you did as well. The more they hear about an issue the more likely they are to fix it .
    I am experiencing this same issue (screenshot taken in landscape mode is saved as portrait, forcing you to have to get an app and rotate it 90 degrees for it to be saved correctly. (the app I'm using is eHarmony... I use Filterstorm to rotate and save a new copy... A pain in the a** because of the steps required.). I'll go and report this issue as well. (iPad2)
  6. #15
    80087
    5 times
    Jul 2011
    285
    the printscreen issue also happens with my ipad2 3g
    for cropping and rotating, i use CROP SUEY HD... so easy to use...
    iPad2 3G 64GB
    SHSH 4.3.3
    JB
    Manila, Phil
  1. Portrait or Landscape?
    By graywolf in forum Apple iPad Polls
    Last Post: 07-27-2013, 06:50 PM
  2. Landscape vs Portrait wallpaper
    By tbrown92030 in forum iPad Wallpapers
    Last Post: 05-23-2011, 07:07 PM
  3. portrait or landscape?
    By ivanmarkchang in forum iPad General Discussions
    Last Post: 05-21-2011, 06:25 PM
  4. No more landscape - portrait lock after 4.2
    By Nathanu in forum iPad Help
    Last Post: 11-25-2010, 12:37 PM
  5. Portrait or Landscape?
    By sbarnes8478 in forum iPad General Discussions
    Last Post: 07-02-2010, 09:50 PM
change orientation of pictures on ipad
change photo orientation ipad
eharmony rotate photo
how to change orientation of photo on ipad
how to change photo orientation on ipad
how to change rotation on ipad picture
how to take screen shot as landscape ipad simulator
web codes to fix picture orientation for ipad
Tags for this Thread
