How to Fix the iPad's Wi-Fi Issues
This is a discussion on How to Fix the iPad's Wi-Fi Issues within the iPad Help forums, part of the Apple iPad Discussions category; Apple confirmed that it's aware of the issues and posted some suggestions on how to fix them: Symptoms: Under certain conditions, iPad may not automatically ...
Results 1 to 7 of 7
    Supporting Vendor
    1374
    5 times
    Mar 2010
    North Jersey
    197
    Symptoms:
    Under certain conditions, iPad may not automatically rejoin a known Wi-Fi network after restart or waking from sleep. This can occur with some third-party Wi-Fi routers that are dual-band capable when:
    • Using the same network name for each network
    • Using different security settings for each network
    Resolution:
    If you encounter this issue, try the following:
    • Create separate Wi-Fi network names to identify each band. This can be done easily by appending one or more characters to the current network name. (Example: Add a G to the 802.11b/g network name and an N to the 802.11n network name.)
    • Ensure that both networks use the same security type (WEP, WPA, WPA2, and so on)
    • If the issue persists, reset your network settings using Settings > General > Reset > Reset Network Settings.
    Note: Always ensure that your Wi-Fi router firmware is up to date.
    Sources:
    How to Fix the iPad's Wi-Fi Issues - Ipad wifi - Gizmodo
    iPad: Does not automatically rejoin known Wi-Fi networks
    iPad Addict
    456
    Feb 2010
    Asia
    1,252
    thank’s for share this info and enlighten Apple care and listen their customer
    66 times
    Jan 2010
    779
    Sweet, thanks for the post.
    2961
    Apr 2010
    oHIo
    does it work?
    iPad Enthusiast!
    2402
    Apr 2010
    Maryland
    32
    Yes ... I took my iPad on a biz trip and upon powering it up in the hotel, no wifi at all ... Downtown Philly has tons.
    I hard restarted the iPad and wifi came back .... It sucks but it's the price of early adopting
    32gb iPad WiFi | Paired with rooted TMobile G1 | Pogo Stylus | Quirky Cloak (on the way) | More accessories coming soon
    BTW - excuse typos as I am almost always posting from my iPad
    LPH
    LPH is offline
    3131
    Apr 2010
    Palmdale, CA
    7
    My iPad connected fine to my home router but kept failing with the Sprint Overdrive. I ended up just changing from WEP to WPA2 Personal and have not had any trouble since.
    Has this worked for anyone else?
    3167
    Apr 2010
    Belgium
    10
    Installed a D-link 615 with wpa! Problems are solved!
d-link ipad problem
dlink ipad redirect
how to fix ipad wifi issues
how to fix redirect issues on ipads
ipad does not automaticaaly join known networks
ipad help
not rejoin wifi
when is an ipad off line how to rectify
Tags for this Thread
