Results 1 to 6 of 6
    22193
    Nov 2010
    Bay Area
    Problems with range extender
    I have a Dlink wireless modem, and a Hawking 300N range extender for the far end of the house away from the Dlink. The ipad works fine on the Dlink wireless. But when I'm at the end of the house that requires connecting to the Hawking extender, I have problems. The ipad says I am connected to the extender, but when I go to open a web page it says it is not available because I'm not connected to internet. The range extender works fine with my Lenovo think pad, so it does work. Visiting friends have the same problems with their iphones.
    Any suggestions?
    iPad Master!
    6869
    4 times
    Jun 2010
    California
    1,278
    I'm using the same setup at work and have no issues, do you have a separate name for the extender? That way you're sure to be connected to the extender and not the weak origin. Also reboot the extender and/or go to settings and forget network then reestablish connection.
    42065
    Range extender issues
    Quote Originally Posted by dlundy7 View Post
    Any suggestions?
    I'm also having the same issue (Netgear WPN824 v3 and Hawking 300N); my laptop connects fine, but neither ipad or ipad2 can consistently hold a signal (even with the range extender, router, and ipads within 3 feet of each other). This is really frustrating. Please help. I've tried forgetting the network, toggling with airplane mode, and restarting.
    32409
    3 times
    Feb 2011
    Arkansas
    200
    I had similar problems and finally solved things by installing 2 Hawking N300s. Someone also suggested using WAP rather than WEP. I also changed channels until I found channel 2 seemed to work best. I think my connection issues were associated more with the signal between the routers.
    Good luck, it is so frustrating when it is unstable.
    Mike
    iPad 3 64GB AT&T 4G, iPhone 4 32GB AT&T
    (wife iPad 3 64GB 4G, iPhone 4 32GB Verizon)
    42065
    Ok, so I think I may have fixed it (my signal hasn't dropped in 3 days and is accessible throughout the house). I was already using WAP as my security setting. I did change the channel to 2. I also changed my available modes to B and G only, instead of Auto 108 mbps (not sure if that did anything, but worth noting). I'm still not getting blazing speeds, but it works fine all over the house. thanks
    209600
    May 2012
    I am another victim of this problem.
  1. Connecting iPad to my range expander
    By Dexlex in forum iPad Help
    Last Post: 11-11-2010, 10:49 PM
  2. ipad compatibility with router extender
    By jerryb2339 in forum iPad Help
    Last Post: 08-18-2010, 11:55 PM
  3. Is iPad WiFi range satisfactory?
    By OmarKN in forum iPad Carriers
    Last Post: 07-30-2010, 06:27 AM
  4. A large range of Ipad accessories
    By IpadOne in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 03-29-2010, 07:52 PM
hawking 300n extender not working
hawking 300n extender troubleshooting
hawking 300n troubleshooting
hawking extender troubleshooting
hawking range extender problem
hawking range extender problems
hawkings range extender problems
ipad range extender
netgear extension on ipad
why is my hawking extender slow
