Results 1 to 7 of 7
    21634
    Nov 2010
    Poughkeepsie, NY
    3G Connection gone!! Only Edge!
    Hi Folks,
    I was having some screen problems a month ago and restored my iPad. Problem solved, but since then, I have not been able to connect to 3G. It only goes to Edge. I thought with yesterday's update things would fix themselves, but no luck. I've tried toggling "cellular data" on/off and also going back a forth between Airplane mode. I am certain I'm in a 3G area.
    Any suggestions?? Thanks!
    ocp
    ocp is offline
    20532
    Nov 2010
    7
    I'm having same issues on 4.2.1.
    iPad Master!
    3239
    Apr 2010
    Missouri
    404
    Same issue for me. I am using 4.2.1 and didn't associate the problem with that until I read other posts about it. I didn't have 3G coverage until today so as far as I knew, it had always been this way! However two other iPads in the house which have not been upgraded have 3G, and mine is the only one that doesn't.
    10073
    Jul 2010
    Brussels (Belgium)
    Quote Originally Posted by cherhall View Post
    Same for me here, upgraded in 4.2.1 and no more 3G juste Edge & GPRS altough my iphone 4 just beside it has 3G full.
    Don't get it....
    Have you in your Settings\Cellular date the option to enable 3G or not ? Because on the iphone i have it, on the ipad i don't have it...altough iphone is in version 4.01
    iPad Master!
    3239
    Apr 2010
    Missouri
    404
    No, the option is not there on iPad to choose 3G. I have tried everything I can think of, still no 3G on my iPad while two others and three iPhones in the house all have 3G.
    16078
    Sep 2010
    Brussels Belgium
    Solution to no 3G
    Just restore your iPad as a new one and it comes back. Make sure you backup everything before. That worked for me!
    iPad Master!
    3239
    Apr 2010
    Missouri
    404
    Restoring worked to get it back, BUT not using my backup. When I put my backup on, 3G was gone again. Had to restore again and set up as new to keep 3G. What a pain! But at least it works now.
  1. My iPad 3G (iOS 4.2 GM) only displays EDGE.
    By DrBRAD in forum iPad General Discussions
    Last Post: 12-05-2010, 09:35 AM
  2. Replies: 3
  3. M-Edge Executive Leather Case
    By Amydave in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 05-25-2010, 03:20 PM
  4. when 3G not available will Ipad use Edge?
    By quiltfanatic in forum iPad Help
    Last Post: 04-06-2010, 10:01 AM
  5. What are the 3 spaces on the bottom edge?
    By Finnedog in forum iPad General Discussions
    Last Post: 03-14-2010, 07:18 AM
3g option disappear from ipad
how to select only 3g in ipad
ipad edge only
ipad only connects to edge
ipad only edge
iphone 4 only edge no 3g
iphone 4s no 3g only edge
iphone edge only
iphone no 3g only e
make ipad connect 3g only
no 3g only edge iphone
why is my ipad always on the edge
