iOS 4.e WiFi FAIL
This is a discussion on iOS 4.e WiFi FAIL within the iPad Help forums, part of the Apple iPad Discussions category; I have an iPad 3g that I've been using for the last several months. Both its 3G and WiFi have functioned flawlessly. I loaded 4.2 ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
    21600
    Nov 2010
    Marina del Rey CA
    Unhappy iOS 4.e WiFi FAIL
    I loaded 4.2 this afternoon. 3G is working flawlessly (thank G-D) but WiFi is "toes up". Once activated WiFi sees our network. It is able to log-on but it is not admitted to our network. Checking Settings-WiFi-On and selecting SheilaNet and then after the WiFi symbol appears on the device (in its usual place) and then ciicking on SheilaNet shows an IP Address of 169.254.159.250. Our network is 192.168.1.nnn. My treasured iPad is unable to connect to the Internet.
    All of our various Windows devices (phones and laptops) are able to log in the SheilaNet.
    I am flummoxed by this problem and would appreciate any suggestions.
    Thank you!
    Ivan
    18528
    Oct 2010
    Bumpass, VA
    43
    By 'our network', I'm assuming you mean your personal, home network? Are you in the position to restart/power cycle your wireless router? If so, try doing that and then try to reconnect your iPad to your network again. I can't say this will prove successful, but I've had need/success with recycling my home's wireless router on occasion.
    18578
    10 times
    Oct 2010
    Virginia, usa
    608
    Also, go into settings and tell it to forget that network, and then, set it up again. You could also tell it to renew the lease. It's giving itself an address instead of getting the address from the router.
    Good Luck
    Pocobear
    4993
    3 times
    May 2010
    St.Louis Mo
    420
    i have a couple of problems since updrading to the new OS. My GPS has me in Vera Cruz no matter how I try to change the position,the GPS is in Manual and wont change to 3G or Wi-fi, and the then Map Quest will not expand,it remains the size of a postage stamp,the same with AAA Trip Tik. Any idea anyone.
    Thanks, Al
    4993
    3 times
    May 2010
    St.Louis Mo
    420
    Since posting the above problems I have worked out the problems with Map Quest and Trip Tic but still have problems with Motion X GPS,looks like I'm not getting any signal from the Satellites.
    Al
    18509
    Oct 2010
    Cicero Indiana
    27
    Quote Originally Posted by Pocobear View Post
    Forgetting the network helped me with a connection issue under the 4.2gm version so definitely give it a try.
    21667
    Nov 2010
    Minneapolis, MN
    12
    This is good advice. The problem appears to lie in the iPad and not the home network.
    20018
    Nov 2010
    Parramatta NSW
    7
    I’ve been happily using my home wireless network for a couple of months and suddenly I get a message “Unable to connect to the network” I’ve searched the forum and tried several solutions to no avail including re booting the modem (x3), and resetting the iPad.
    In settings – Wi-Fi, under “Choose a Network” it shows my “default” home network with a pad lock and a full strength signal. When I ‘click’ on it, I am asked for a password. I have tried the network key, and my iPad password but I get the message “Unable to connect to the network default” then Dismiss.
    Dummy that I am, I do not know how to tell it to forget that network nor how to renew the lease.
    18578
    10 times
    Oct 2010
    Virginia, usa
    608
    Tap on the little blue arrow to the right of where you see your network name and the lock icon. Tap on "Forget this Network" at top of screen. "Renew lease" is at the bottom of that page if you want to try that first. I would just "forget this network" and reset up you password/phrase, rather than "Renew lease" under the circumstance.
    Good Luck
    Pocobear
    Banned
    428
    2 times
    Feb 2010
    Japan and Seattle
    1,131
    Upgraded to 4.2 today, no problems with Wi-Fi whatsoever.
  1. Will iPad Fail in School?
    By theipadstudent in forum iPad General Discussions
    Last Post: 08-01-2010, 04:01 AM
  2. Zagg Packaging FAIL
    By Linkreincarnate in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-09-2010, 06:46 PM
  3. how turn wifi OFF/ON without the need to reenter wifi password
    By lse123 in forum iPad General Discussions
    Last Post: 07-08-2010, 11:06 PM
  4. Sold my 16gb wifi and wait for 32gb wifi is killing me
    By Ian B in forum iPad General Discussions
    Last Post: 06-29-2010, 06:19 PM
  5. Setting up Verizon Blackberry Tour Wifi Hotspot for Ipad Wifi
    By xlr8nflorida in forum iPad General Discussions
    Last Post: 06-14-2010, 11:09 PM
blank ip address ipad
ewifi 4.2.1
ewifi ios 4.2.1
i pad 4 forget lease
ios blank ip address
ios renew lease
ios wifi renew lease
ipad blank ip address
ipad ip address blank
ipad ip address empty
ipad renew lease wifi
wifipass for ios4
Tags for this Thread
