Apple ID problem
This is a discussion on Apple ID problem within the iPad Help forums, part of the Apple iPad Discussions category; My app icon is showing 3 "free" updates available for keynote, pages, and numbers.....when I try and install, the wrong user id shows up (our ...
Apple ID problem
My app icon is showing 3 "free" updates available for keynote, pages, and numbers.....when I try and install, the wrong user id shows up (our IT director who had set up the ipad for me) and therefore my password does not work. I have gone to "settings" and "store" and signed out and back in. It shows up correctly as my account. I am able to d/l other apps without a problem.....it is only the updates to the apps above that are the problem....any suggestions?
11-22-2010 10:06 PM
I would sync them then d/l the updated versions on your pc then sync.
iPad Master!
You'll still need the original purchaser's id to update.
Originally Posted by
BrennB
Brenn...I have his id, but not his password....can you explain.....
iPad Master!
Well the apps were installed by his IT so the updates are linked to his account. Just take the iPad to him and do the update so he can input his password..
With out his password you cannot upgrade it is that simple if you cannot obtain his password then you have no option other than to purchase the apps your self.
iPad Master!
Yeah, since he said it was his IT director I figured it was a work option so he should be able to have IT set the updates as they come
BrennB
Gotcha...thx (to Col.Bris too!)
Ok...I think I still need help..and maybe need to clarify...I have an apple ID and password and it allows me to purchase apps-no problem-accept for the 3 apps (keynotes, pages and numbers) that show there are updates available...when I try and update that is the only time the other id appears that is not mine and asks for a password. I have tried synching with itunes, signing in and out etc....when I got to settings on the ipad it shows me as the person signed in for the id. I had one thought and that was to delete the 3 apps and reinstall..anything else to try?
Any way to "undelete" apps?
Bajanjack
Well of course I screwed up....I was able to delete the 3 apps noted above...when I went to reinstall, thinking that would solve the id log in problem, I discovered I have to pay for them.....any way to recover the apps I deleted without paying?
- You may not post replies
- You may not edit your posts
Forum Rules
By cultman1 in forum New Member Introductions - Site Assistance
Last Post: 06-07-2010, 02:16 PM
apple id is incorrect on ipad
apple wrong user id
i-pad is using wrong apple id
ipad apple id problem
ipad apple id problems
ipad update has incorrect apple id
iphone shows wrong apple id
my iphonekeeps showing wrong apple id
there is a problem with my apple id it has a different user
trying to update app and my apple id doesnt come up
why is my apple id on my ipad for updates wrong
wrong apple id on ipad
