Download ipad update problem
This is a discussion on Download ipad update problem within the iPad Help forums, part of the Apple iPad Discussions category; So ive been trying to download the new ipad update ALL DAY. Each time it has .1 megabytes to go and then it says someething ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
    11353
    Aug 2010
    Arkansas
    9
    So ive been trying to download the new ipad update ALL DAY. Each time it has .1 megabytes to go and then it says someething about a network connection timed out. My internets perfectly fine as you can see sence your reading this post on the internet. Anyone else having this problem? Any fixs?
    10163
    Jul 2010
    Las vegas
    106
    Yup, same thing happening to me. It's also saying about a disk full. I'm on my last ten minutes For the second time and see what happens.
    22070
    Nov 2010
    Hi, first - sorry for my English.
    I think the problem is with your antivirus software. I have the same error (time out internet connection when finish download update) but when I close antivirus NOD32 everything is ok, now I have 4.2 OS in my Ipad. Try this
    iPad Ninja
    5787
    21 times
    Jun 2010
    2,282
    You could try downloading via bittorrent. If you don't have it might I suggest uTorrent as it's small, fast and free.
    When the file is downloaded, fire up iTunes and when it offers to download the update refuse, just hold down the option key and click on update. It will then ask for the file to use. Point it at the right one and let it do it's stuff. When it's done the iPad will restart and resync.
    27918
    Bilambil Aus
    Pakan,
    Thanks for your input, I have been trying to rectify this problem for 3 days without resolve, your advice has been great
    Thanks Gjay
    38488
    Louisiana
    Angry iPad is frozen
    After being unable to download the latest iPad upgrade (ios 4.3), my iPad is now frozen with a picture of the USB cord and the I-Tunes logo. I cannot turn it off, or on and I cannot restore it to factory settings (error 3014). I called support and was told that the security firewall was preventing connection with Apple. My security software is AVG and I cannot figure out how to disable the software.
    Why didn't Apple state that firewalls have to be disabled before uploading the latest software? I am upset.
    35386
    Feb 2011
    London
    102
    Quote Originally Posted by Cajun dancer View Post
    OK, I have had same problem in London today. Went on pc for my weekly sync and was told there was an apple upgrade ready. I set it off and it immediately told me it would take 3-4 hours!
    That sent alarm bells ringing as was not expecting such a long time.
    When I returned it had crashed and would not come back on, just the lead and logo as you got above, then it told me on pc to reset the whol ething and that data would be lost. Not a happy bunny me.
    After calling tech desk they just say its an error with the upgrade downloading and that is it, that is it! Ned to reset to factory settings.
    So I tried this and that failed too, as you found.
    So have appt. with apple store tomorrow morning and will be asking for money back (4 months old). I think this reconditioned one they stuck me with will always be trouble. Lost faith. I cant be putting in so much data to have it just fail...and all my ipad calendar entries will be gone as never had it backed onto google yet , aaaarrrrggghhhhh.
    S
    23484
    Dec 2010
    Iowa
    6
    I'm having the same problem with my PC. I was able to download and save on my PC, but don't know how to have the update command ask me for the location!
    PC doesn't have an Option button, and Alt doesn't seem to work.
    HELP,
    23484
    Dec 2010
    Iowa
    6
    HELP,
    38488
    Louisiana
    Solution
    My IS department staff sent me a website to disable my security software, and I was then able to restore the iPad to the original factory setting. Since I had backed up everything on my computer into iTunes before the upgrade, I was able to retrieve and restore all of my Apps, music, etc. My iPad is working beautifully. Now my husband can play Angry Birds and not be angry with me.
    Next time there is an upgrade, believe me, I will disable the security software first. If anyone has AVG, disable only the Resident Shield and the download should be no problem.
  1. Large app download problem
    By pattymac555 in forum iPad Help
    Last Post: 11-17-2010, 04:51 PM
  2. App Download Problem
    By ggildeme in forum iPad General Discussions
    Last Post: 10-17-2010, 06:05 PM
  3. Replies: 4
    Last Post: 09-12-2010, 07:22 PM
  4. Cydia update problem
    By Luketaytay in forum iPad Hacking
    Last Post: 08-17-2010, 06:35 PM
ipad software download timeout
ipad software update download timeout
ipad software update problems
ipad software update timeout
ipad software update times out
ipad update download
ipad update keeps timing out
ipad update problems
ipad update timeout
problem downloading ipad update
problems downloading ipad update
trouble downloading ipad update
