Jailbroken iPad Won't Sync With iTunes or Charge
This is a discussion on Jailbroken iPad Won't Sync With iTunes or Charge within the iPad Help forums, part of the Apple iPad Discussions category; Ok, here's the deal: I have a jailbroken with limera1n 16GB WiFi iPad. I decided that I didn't want the jailbreak anymore, and for some ...
Ok, here's the deal: I have a jailbroken with limera1n 16GB WiFi iPad. I decided that I didn't want the jailbreak anymore, and for some reason thought that deleting limera1n, which was an option in the app icon, was a good idea. Now, however, my iPad is no longer syncing with iTunes OR charging via the wall charger, and I can't get my computer to recognize it when it's connected. I also haven't found anyone else with this problem through google searches, and I'm running out of ideas.
I'm backing up my entire iTunes library as we speak to do a full uninstall and reinstall.
Can anyone please help me? I'm running an April 2010 Macbook Pro 15" model, and I'm desperate to get my iPad restored asap. I have roughly 59% of the battery remaining.
11-21-2010 03:18 PM
iPad Guru
Originally Posted by
hotphoenix
As was stated in the limera1n app...deleting it does NOT delete the jailbreak. You have to restore your iPad or update to a higher version to remove it. I restored in order to install 4.2.1 and it works just fine.
I understand that. But I'm unable to restore it because my computer won't recognize that the iPad is connected at all. It recognizes my iPhone just fine, and I've tried multiple UBS cables and multiple restarts, but it's not detecting my iPad.
Sounds like it's time to put it in dfu mode and restore.
iClarified - iPhone - How to Put an iPhone Into DFU Mode
iPad Guru
blackweather run it to quickly and easily get it into DFU.
Dannyboy85
Followed the directions, the screen is black as it should be, but iTunes is not responding.
gentlefury
blackweather - run it to quickly and easily get it into DFU.
Blackweather isn't working either. I'll reinstall iTunes once I've finished backing up and post an update, see if that works.
iTunes reinstall didn't work.
Would enabling the 'Erase All Content and Settings' function from the General menu work to reformat my iPad? My computer isn't recognizing it, so it seems like something has to be done more on the iPad end of things.
iPad Guru
hotphoenix
So you can use your iPad? Yeah try factory reset. If that doesn't work then just bring it to an Apple store...they will swap it out. You said you deleted cydia and limera1n right?
gentlefury
Very informative! Thank you!
gentlefury
Yeah, I can still use the iPad, I just can't get my computer to recognize it to sync or restore anymore (oddly enough, I found a thread on a similar issue here on MacRumors--I'm also in France for the year, and I know it's not a wire or hardware problem, and it just happened today).
I deleted limera1n, but I haven't tried to delete Cydia yet, since it's not as easy. If this factory restore doesn't work, I don't particularly want that to be on there when I take it to the Apple Store in Paris, so from what I understand, it might be best to use something called Cydelete to remove it like a regular app?
- You may not post replies
- You may not edit your posts
Forum Rules
By qwerty in forum iPad Help
Last Post: 07-19-2010, 11:57 PM
By yhkhong in forum iPad Hacking
Last Post: 07-03-2010, 12:02 AM
By jimt29 in forum iPad Accessories for iPAD 1, 2 and 3
Last Post: 05-14-2010, 10:35 AM
By jimt29 in forum iPad General Discussions
Last Post: 05-09-2010, 07:35 AM
after jailbreak my ipad 2 now itune doesn't recognize my ipad 2
bricked ipad wont charge
ipad jailbreak wont update itunes
ipad won't appear on computer after jailbreak
ipad won't charge jailbroken
jailbreak ipad won't sync
jailbroken ipad cannot sync with itunes
jailbroken ipad doesnt charge
jailbroken ipad unable to sych after itune upgrade
jailbroken ipad won't charge
jailbroken ipad wont charge
why wont itunes pull up my jailbroken ipad
