when 3G not available will Ipad use Edge?
This is a discussion on when 3G not available will Ipad use Edge? within the iPad Help forums, part of the Apple iPad Discussions category; Was wondering if you live in an area where 3G is spotty, if edge will provide you with service on the Ipad 3G?...
04-05-2010 01:48 PM
Originally Posted by
quiltfanatic
Good question, I would assume that it will degrade gracefully to Edge similar to an iPhone, but I'm not positive.
iPad Master!
I'm curious since it's just a data plan if the signal will be better than telephony+data plans. I heard edge is like dial up for data.
iPad Master!
That's being gracious.
I consider 3G to be dial-up for data, Edge is very slow dial-up for data
iPad Master!
Wolffmann34
I stand corrected...
iPad Master!
On a more direct answer to your question, all 3G hardware will drop back to Edge (2G) when there is no 3G available.
I use commercial modems for work and they are strictly Edge. At this point Edge is so slow that many applications time out before it can transmit the data.
iPad Master!
According to the AT&T signal map I'm in the strongest area but o guess I'll know the truth soon enough.
You can get over 100kbps over Edge which isn't as bad as dialup (which maxxed out at 56kbps, but realistically couldn't go over 52kbps) -- There were a lot of Nexus One owners who could only use Edge since they used the Nexus One on AT&T. They got up to 300kbps sometimes.
So, it's not quite dialup more like ISDN on Steroids
iPad Master!
JohnnyApple
So now, 'I' stand corrected.
I guess the internet is just so media intensive now that having 100k feels like in the dial up days when you had a poor phone line and could only get a 14.4k connection.
- You may not post replies
- You may not edit your posts
Forum Rules
By Finnedog in forum iPad General Discussions
Last Post: 03-14-2010, 07:18 AM
3g not available
can ipad 3g use edge
can ipad use edge
can you use edge on ipad
does att use edge when 3g is unavialable
does ipad 3g use edge?
does ipad use edge
does ipad work on edge
edge data ipad
edge for ipad
edge ipad tim
how to use edge on ipad
how to use edge on ipad 3g
how to use edge service
ipad data edge
ipad edge
ipad edge data
ipad edge service
ipad operate on edge
ipad use edge
Tags for this Thread
