Results 1 to 10 of 10
    iPad Enthusiast!
    2039
    Apr 2010
    calif
    47
    completely stuck with desktop connect
    First I want to say how much I enjoy the ipad 64gig. Now my problem. I purchased desktop connect from Apple Store and syced it to the ipad. I then downloaded tightvnc beta as I have win7 64bit. In the vnc I entered the password so now when I open desktop connect a window appears asking for password so after entering it I am dead in the water, Nothing to see a command or no button to push. Thats it. I sent a email to desktop connect but no answer. Any help will be appreciated. jim_joh
    54 times
    Jan 2010
    771
    Quote Originally Posted by jim_joh View Post
    Jim,
    Are you trying to view your "Desktop" on your iPad or vice versa?
    The Desktop connect allows you to connect to your main PC/Mac and control it from the iPad. You need to run a VNC / Remote Desktop client on your PC or Mac to allow the iPad to connect to it.
    I do not believe TightVNC offers a server, only a client.
    Do you have a PC or Mac?
    iPad Enthusiast!
    2039
    Apr 2010
    calif
    47
    Thanks for the responce. I am trying to see my pc with win7 64bit on the ipad. I guess I am over my head jim_joh
    54 times
    Jan 2010
    771
    You just need a VNC server on your Windows PC.
    The Free version from RealVNC.com is here:
    RealVNC - VNC Server Free Edition 4.1 for Windows
    They have some instructions... but mainly you need to install the server on your PC and setup a password. Then, from your iPad you'll need to know the IP of your Windows PC and you should be able to connect!
    iPad Enthusiast!
    2039
    Apr 2010
    calif
    47
    Back to square one. I down loaded the realvnc but when I open "desktop Connect" on my ipad there is a window with 6 squares for password, After entering the pass word for vnc there is no command on the ipad widow to do any thing at all. I have tapped all over but nothing. If I click the key board to hide it the password I entered disappears. Everytime I click desktop direct icon this window and only this window comes up so I am dead in the water. One good thing has happened. I purchased "readdledocs" and what a great program it is. thanks for your ideas jim_joh
    iPad Enthusiast!
    2039
    Apr 2010
    calif
    47
    Angry completely stuck with desktop connect
    Please I need a answer to my problem. I have sent 2 emails to Antecea and no answer. Also I looked at the forum on their web site and others have the same problem and no answer. Also their web site says with windows7 use tightvcn, Again when I open "desktop connect" on the ipad only one window comes up asking for passcode and when you enter it nothing & I mean nothing shows to click to proceed. jim_joh
    iPad Junkie!
    1589
    Mar 2010
    Seattle WA
    203
    Jim joh, I am a believer of the squeaky wheel getting the grease. Have you gone back to the apple store and talked to the person that suggested the software to you?
    I can bet they could be cajoled into just giving you a replacement iPad for the one you have, just so you don't have a nice looking small boat anchor.
    I only read portions of your post so i am not really sure why you went down the path you did, but maybe it's time to re-group and follow the path of least resistance and install itunes on your windows system and start enjoying your iPad.
    iPad Enthusiast!
    2039
    Apr 2010
    calif
    47
    Thanks gudua but my ipad is working great and this has to be a software problem. I think the problem is do in the lack of instructions in installing the program and I am hoping to find somebody that has installed it. In the mean time I have asked Apple itune store to refund me. jim_joh
    3141
    Apr 2010
    desktop connect works great for me!
    Jim Joh!
    After you type in your VNC password just Press the NEW COMPUTER button at the top left corner of the screen to save your password and it works great for me!
    iPad Enthusiast!
    8907
    Jul 2010
    Los Gatos, CA
    82
    if you are refering to desktop connect by Antecea Desktop Connect Antecea you need a google account to use it .
    not sure if this is what you mean as you mentioned "desktop connect" and "desktop direct" , so perhaps your using
    the term in the generic sense instead of product name.
  1. No wifi here, can I connect through MacBook Airport???
    By Finnedog in forum iPad General Discussions
    Last Post: 04-04-2010, 12:52 AM
  2. Apple fastracked Memeo Connect for iPad to App Store...
    By AbblePC in forum iPad General Discussions
    Last Post: 03-31-2010, 06:48 PM
  3. Apple fastracked Memeo Connect for iPad to App Store...
    Last Post: 03-31-2010, 04:09 PM
  4. Can the iPad replace the desktop or laptop?
    By ipad987 in forum iPad General Discussions
    Last Post: 03-23-2010, 08:13 PM
  5. Replies: 4
    Last Post: 02-08-2010, 02:19 AM
desktop connect ipad
desktop connect ipad set up
desktop connect ipad setup
desktop direct ipad
how do i set up desktop connect for ipad
how to set up desktop connect
how to setup desktop connect
how to setup desktop connect ipad
how to use desktop connect
how to use desktop connect ipad
ipad desktop connect setup
setting up desktop connect ipad
Tags for this Thread
