ipad not swithching on
This is a discussion on ipad not swithching on within the iPad Help forums, part of the Apple iPad Discussions category; my i pad is not turning on . no charging ., basically nothing happen wht to do plz help...
Results 1 to 4 of 4
    21148
    Nov 2010
    india
    17419
    2 times
    Oct 2010
    Texas
    646
    Try a soft reboot hold home & power for about 10 seconds until the apple logo appears then just let it reboot.
    Everything is Bigger in TEXAS!!
    iPad 16GB WiFi
    iPhone4 32GB
    Be sure and check out iphone4forum.net! For anything iPhone..
    Me over on the other side...
    iPad Junkie!
    16514
    Oct 2010
    Somewhere?
    113
    Smile Is your ipad out of charge?
    Umm...did your ipad run out of battery? I mean once drained to zero it takes about 2 to 3 minutes for ipad to comeback after connecting to the 10W charger. And in zero battery state ipad wont turn on at all,but with little power it will show a red battery too. Its obvious but most often people miss obvious stuff and panic resulting in total frustration. There is a possibility of overheating too which shows a notification though. Connect to the 10W charger,wait for 5 minutes and then hold the power button and see if it comes back. What happened before total die out? Did it just die like that while using your ipad or you just left it and it went out?
    iPad 3G (32GB)
    iOS 4.3
    iPad - The awesome tablet that matters
    19371
    Nov 2010
    United Kingdom
    20
    Quote Originally Posted by iwhat View Post
    Yeah,the iPad does seem to take significantly longer to come back to life after it's been completely drained compared to the iPhone and Touch, probably because of the sheer size and capacity of the battery in it. Threw me into a panic the first time I drained it
    I've still never been able to overheat the thing, though - must be doing something wrong
ipad 1 not turning on or charging
ipad is not turning on or charging
ipad not charging or not turning on
ipad not charging or turning on
ipad not turning on
ipad not turning on or charging
ipad not turning on when charging
ipad will not charge or turn on
my ipad is not charging or turning on
my ipad is not turning on or charging
what happens when ipad battery dies how long before it comes back on
what happens when ipad battery runs out
