WiFi Operating Distance
This is a discussion on WiFi Operating Distance within the iPad Help forums, part of the Apple iPad Discussions category; Hi I am finding the range of my Ipad is not as good as my PC's when operating to my WiFi router (Netgear RangeMax). In ...
Results 1 to 2 of 2
    19691
    Nov 2010
    North Cave, E Yorks, UK
    Hi
    In some rooms of my house I can happily access the net with my PC's but not Ipad. It only works over quite short distances from the router. Is anyone else come across this issue and is there a resolution.
    Regards,
    Terry
    18578
    9 times
    Oct 2010
    Virginia, usa
    608
    Try this, go into SETTINGS - GENERAL - NETWORK, then chose the line with your network name on it and then press the blue arrow on the right, then tap the FORGET THIS NETWORK button at the top of the page. Then setup you network again. OR, you can try to tap RENEW LEASE and see it that helps. The first option above is the best one to try, as it resets everything in the network settings. This worked for me when I had a low signal two foot from the wireless router and could not connect.
    Good Luck
    Pocobear
  1. how turn wifi OFF/ON without the need to reenter wifi password
    By lse123 in forum iPad General Discussions
    Last Post: 07-08-2010, 11:06 PM
  2. Sold my 16gb wifi and wait for 32gb wifi is killing me
    By Ian B in forum iPad General Discussions
    Last Post: 06-29-2010, 06:19 PM
  3. Setting up Verizon Blackberry Tour Wifi Hotspot for Ipad Wifi
    By xlr8nflorida in forum iPad General Discussions
    Last Post: 06-14-2010, 11:09 PM
  4. Replies: 0
    Last Post: 04-18-2010, 09:00 PM
apple tv distance
how to search short-range distance wifi
ipad wifi distance
ipad wifi distance range
ipad wifi short range
my ipad wify not work in some rooms in house
wifi operating distance
wifi operating range
