Help on 3.2.1
This is a discussion on Help on 3.2.1 within the iPad Help forums, part of the Apple iPad Discussions category; Help on 3.2.1 Please some one help me out. I am running on a spirit jail break on 3.2.1. I went to do a restore ...
Results 1 to 4 of 4
Thread: Help on 3.2.1
    17983
    Oct 2010
    Ca
    Help on 3.2.1
    Help on 3.2.1
    I am running on a spirit jail break on 3.2.1. I went to do a restore and upgrade to 3.2.2 and re jailbreak with limera. When I go to do a restore on iTunes I get an error that says that it can not it can not access the updater files. So in long story short I can't update anything in version.
    Another question I have is since I am jail broken, if I update and reinstall cydia will I loose all the changes that I have done with cydia as in terms of licenses. Thanks for the input.........
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    yes you will loose all your jb apps and changes.
    a restore, wipes out everything and loads your backup files back onto it.
    18578
    10 times
    Oct 2010
    Virginia, usa
    608
    No, you will not lose your licenses. If you use an app like "pkgbackup" from Cydia and use SBSchedualer from Cydia with it, you can backup all your apps and settings. Go into Pkgbackup settings for backup and check all the blocks. If you downloaded SBSchedualer you will be able to restore all of your settings also. So, when you restore, re-jailbreak and then re-download PkgBAckUp and install it, then do a restore within PkgBackup. This will re-download all your apps from Cydia and apply most all of your settings.
    Good Luck
    Pocobear
    17983
    Oct 2010
    Ca
    Thanks guys.
    Thanks guys. I backed up files and did a restore and rejailboak with jailbreak mw. Things are running way faster. I still can get to 3.2.2 because I get error 3002 every time I go to update.
