Improving WiFi coverage
This is a discussion on Improving WiFi coverage within the iPad Help forums, part of the Apple iPad Discussions category; For once this is not a moan about Ipad Wifi reception. Instead I need to boost my wifi area in the house as it doesn't ...
Results 1 to 7 of 7
    12205
    Aug 2010
    Devon, England
    96
    Instead I need to boost my wifi area in the house as it doesn't extend more than about 6 metres from the router whatever I am using, whether it is the Ipad or laptop. Are there any signal boosters or other equipment to boost the signal throughout the house?
    Thanks,
    Peter
    1596
    166 times
    Mar 2010
    4,565
    What brand router are you using?
    I recommend a net gear 300 n router but there are are others
    Cheers Colin,
    Brisbane Australia
    _____________________________
    iPad User Guide
    Forum Rules. Please Read.
    Hacking Section Rules
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    Is your house built with lead walls??
    I agree with my esteemed colleague that a new router is most likely in order. It is not necessary to get a top of line line model. I have a D-Link DIR-615 which is pretty much their entry level 802.11n router and it works great!
    I live on 3 acres and my router is in the "man cave" in the corner of the house with the red arrow and I have good coverage over the entire property. (I listen to streaming music on my iPod Touch while cutting grass)
    18578
    10 times
    Oct 2010
    Virginia, usa
    608
    What I have done is too set up 3 units of the same brand, use the same SSID and password on each one and then set each one to a different channel spaced at least 2 channels apart, more is better. I live in a large brick house with some brick walls between rooms, as they were added on. I live in the middle of 135 acres so I don't have to worry about interfering with others. Two units should work fine in most cases with some trial and error in placement. Tried booster units, but they were slow and erratic. Just another thought. If you live in close to others with WiFi just try another channel, you may be getting interference from your neighbors.
    Good Luck
    Pocobear
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    Upgrade to an 802.11N router if you already have not done so.
    also if your a Techie type of person that likes to do this kind of stuff you can pick up either an 802.11N router that supports wireless bridging or pick up one thats compatible with DD-wrt.
    DD-wrt is a custom open firmware for wireless routers that you can install to give you more options. My main router is a Cradlepoint MBR1000 with a backup Verizon aircard to keep the internet up if the cable company ever goes out.
    Then I have a 802.11N netgear router that I installed DD-wrt on. I set this router up to connect to the main router and then share the internet out with devices that are connected. Also with DD-wrt I am able to set up Multiple SSID's that broadcast and are on their own VLan. If anyone tries to bypass the security and jump on the network, there gonna have to go through a few SSID's first before finding the valid one.
    iPad Ninja
    5787
    21 times
    Jun 2010
    2,282
    Like your thinking Mike.
    12205
    Aug 2010
    Devon, England
    96
    I use a Netgear DGN1000, only eight months old. Took hours on the phone to Netgear to get it set up.
    It could just be a piece of cra*p that never worked properly. Perhaps I should take it back!
  1. $100 Replacement Coverage
    By bap11 in forum iPad General Discussions
    Last Post: 03-27-2013, 05:28 AM
  2. Breakage coverage
    By gammadoc in forum iPad General Discussions
    Last Post: 08-26-2010, 03:25 PM
  3. No ATT 3G coverage.
    By MTFire33 in forum iPad Carriers
    Last Post: 06-29-2010, 08:33 PM
  4. Optimizing coverage with my "wimpie" WiFi version
    By Newenglandguy in forum iPad General Discussions
    Last Post: 06-16-2010, 09:39 AM
  5. iPad and E3 Coverage
    By mossman in forum iPad General Discussions
    Last Post: 06-13-2010, 09:23 PM
custom netgear firmware dgn1000
dgn1000 custom firmware
dgn1000 dd-wrt
dgn1000 ddwrt
dgn1000 hack
how to improve ipad wifi symbol
improving wifi coverage
netgear dgn1000 alternative firmware
netgear dgn1000 custom firmware
netgear dgn1000 dd-wrt
netgear dgn1000 firmware dd-wrt
wifi coverage ipad
