Results 1 to 10 of 10
    18889
    Oct 2010
    Denmark
    11
    Cisco Ipsec VPN problem
    Hi all
    Im new to iPad and have been playing with the vpn in this device.
    My company has a Cisco VPN concentrator and I would like to connect to my companys network with the iPad.
    Im able to establish the vpn tunnel, that is I think so, the icon for VPN is in the top bar on the homescreen.
    But im unbale to access any resources, fx webpages on the company internal server, RDP to servers and so on.
    Is it possible to see the VPN ipaddress? or does anyone have any idea whats wrong.
    18938
    Oct 2010
    Honolulu, HI
    24
    might want to check with your network admin
    15" Macbook Pro, iPhone 3gs 4.1 JB'en, iPod Touch 3G JB'en, iPad
    18889
    Oct 2010
    Denmark
    11
    Ok, ill do that. Done that. I am the network admin does you know if there are some special settings that has to be enablet for vpn on the ipad?
    The vpn works with both mac and windows.
    18938
    Oct 2010
    Honolulu, HI
    24
    The iPad VPN supporting the L2TP, PPTP, or Cisco IPSec VPN protocols
    Tap Settings > General > Network > VPN > Add VPN Configuration. Then use the VPN settings for your device.
    * Server = your computer's external IP or hostname.
    * Account = your account login
    * RSA SecurID = OFF
    * Password = your account password
    * Secret = computer's secret, chosen during set-up.
    * Send all traffic = ON
    Turn VPN on or off
    If you have created a VPN configuration, you would find the option to turn VPN on or off in the Settings.
    First disable Wi-Fi on iPad, then start VPN in the settings. Wait until it finishes connecting and the status bar would has the VPN icon.
    Note: iPad will drop VPN whenever changing the networks.
    Try the following to use your iPad to connect to Cisco VPN.
    * On your iPad, tap Settings > General > Network > VPN > Add VPN Configuration...
    * In the top of your window, Click on IPSec tab from the list of connection types.
    * Enter the your Cisco VPN information:
    Description: VPN
    Server: yourvpn-domain
    Account: Your NetID
    Password: Your NetID Password
    Group Name: your group name
    Secret: *****
    Turn Proxy off.
    Click Save.
    * Sliding the VPN swith to On.
    18889
    Oct 2010
    Denmark
    11
    Thanks, but as i wrote, im able to connect to vpn, but unable to reach any resources.
    Is there some way to see the vpn ipaddress?
    Do you know if there is an commandpromt app?
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    Quote Originally Posted by jjlp View Post
    sounds to me like you didnt even give rmart73's suggestion a try or verify that everything is the way it should be.
    and for being a network admin you seem to just be wanting everyone to give you the answers and do it for you rather than just looking at it yourself.
    If you would have looked at your VPN settings area there will be a STATUS section noting the IP of both the server connected to, and the IP issued to your device.
    18889
    Oct 2010
    Denmark
    11
    Quote Originally Posted by MikesTooLz View Post
    Im very sorry for the inconvenience that i may have caused, as I wrote im total noob to iPad and have looked for the vpn status, but found it now so thanks you so much.
    I have been looking into my vpn settings and verified that that part was ok, apparently im unable to connect to vpn using 3G but that can maybe a ipad or carrier error.
    ill look further into the error.
    19725
    Nov 2010
    Post
    I find that I am having the same issue. I have an Ipad that had the VPN setup to go to a cisco 3030 concentrator, work great for about 4 months now the vpn will connect but pass no data. I have deleted the vpn and recreated and can see the connection on the concentrator. Does anyone have any ideas?
    23218
    Dec 2010
    SLC
    VPN errors.
    If you are successful with your VPN connection from your iPad meaning that it looks/says it is connected but you just can't see/send/receive traffic from your iPad then you need to check this from the VPN side.
    I am familiar with several Cisco VPN's and the concentrators are not nearly as nice as the ASA's but they still have decent logging. You need to log on to the VPN and watch the live traffic/connections. And if you can provide the error from there it would be easier to troubleshoot.
    If connected it's a VPN issue and not an iPad issue. And more than likely some ACL or policy but without details from the VPN side it's hard to call.
    At some point this weekend I will bring an old VPN 3000 concentrator up and see what I can find...
    31804
    Feb 2011
    St Louis
    I too have been having problems with IPad VPN connecting into work.
    I have everything configured correctly for an IPSec VPN and I connect in just fine. I can use iSSH to connect to a couple Unix servers that are on a private IP space. However, when I use iTap RDP to connect to Windows Servers, it does not work.
    My windows servers sit in a DMZ and they have public IP addresses, but can only be accessed from inside my work network (thus requires VPN). When I use iSSH, I can see TCP connections being built in my VPN Firewall, thus I know the VPN is working. Now remember, these are the unix servers with private addresses.
    When I use iTap for RDP, I do not see any matches on the firewall. It appears that for public addresses, the IPad IOS is preferring to use the general network connection instead of the VPN connection (thus not reaching the servers in the DMZ).
    I see on PPTP and L2TP VPN you can select to "Forward all Packets" which from my understanding adds the default gateway to the VPN connection. I do not see this option for IPSec.
    Can anyone give up any suggestions to a fix for this problem? It seems really strange that the IOS would not route everything through the VPN connection.
  1. Cisco VPN not connect
    By r62861848 in forum iPad General Discussions
    Last Post: 03-08-2011, 07:58 AM
  2. IPSEC VPN group name
    By charden in forum iPad Help
    Last Post: 07-16-2010, 01:29 PM
  3. Weak signal with Cisco M10 WiFi Router
    By jfdonohoe in forum iPad Help
    Last Post: 07-08-2010, 08:28 PM
  4. RDP and Ipsec VPN apps
    By ratatapa in forum iPad Apps
    Last Post: 07-02-2010, 07:18 PM
  5. Cisco suggests WiFi Flip Video camera by Christmas
    By iPadPil in forum iPad General Discussions
    Last Post: 07-01-2010, 09:57 AM
cisco ipsec vpn ipad
cisco vpn for ipad
cisco vpn ipad
harvard vpn ipad cisco secret
i dont know what info to put for vpn on ipad for new settings
ipad ipsec vpn
ipad ipsec vpn problems
ipad ipsec vpn setup
ipad rsa cisco
ipad vpn cisco
ipad vpn connection problems
ipad vpn problem
