Michael,
Thanks for the response and apologies for the vague post. I can connect to itunes and synch correctly but it does not show in the computer section of windows. I'm not sure how important that is though.
regards,
Arctic
This is a discussion on Ipad Wifi Bridge conection within the iPad Help forums, part of the Apple iPad Discussions category; Michael, Thanks for the response and apologies for the vague post. I can connect to itunes and synch correctly but it does not show in ...
Michael,
regards,
Arctic
Ahhh OK. That is not really all that important. The only thing you would see is photos and images in the camera roll/Saved Photos. You might not even have anything in Saved Photos yet so perhaps that is why it is not showing.
Try this: from any screen press the sleep and home buttons at the same time. This will take a screenshot of the current screen and put it in Saved Photos (same thing as Camera Roll on iPhone). Then go into the Photos app and make sure it is there. It should be the first thing there.
Once you confirm you have something in Saved Photos, then try connecting to PC again... disconnect and plug back in if you need to. In Computer/My Computer you should see your iPad. Clicking into it should show any photos in Saved Photos so you can copy them to PC.
Actually before you get to that you should see a popup asking you what you want to do with the iPad. Choose to open folder to view files. You can turn that feature off, so the popup doesn't appear. I have it off because I find that annoying.
Michael
