UCB Inspirational Radio
This is a discussion on UCB Inspirational Radio within the iPad Help forums, part of the Apple iPad Discussions category; I am unable to use this app after installing mini jawbone,each time I try I get 'Error unable to download configuration.Please check your connection' However,it ...
Results 1 to 4 of 4
    166698
    Feb 2012
    46
    However,it does not affect another radio app.
    Can anyone help ?
    1544 times
    Walla Walla, WA
    15,464
    Try going to Settings > Bluetooth, selecting the jawbone and forgetting it.
    If when the app starts working again, you can try pairing the Jawbone again and see if it still causes problems.
    You can also try the usual fixes, to see if they make a difference. I might just be a coincidence that the app is failing, and not the Jawbone at all.
    The Usual Fixes
    Close/Clear the app:
    iOS 6: With the problem app closed, double tap on the Home button to get the multitask bar. Tap and hold on any icon in the bar until they jiggle, then tap the minus sign on the problem app.
    iOS 7: Double tap the Home button to get the multitasking display. Swipe up on the problem app's thumbnail image (not the icon).
    Reset All Settings: Another, somewhat more drastic thing you can do is Reset All Settings. You'll find this under Settings > General > Reset > Reset All Settings. It won't erase any of your content, apps, or accounts; but you will have to go through most of your other settings and re-tweak them back to your liking. Do not confuse this with Erase All Content and Settings.
    More detailed information at: iOS: Not responding or does not turn on
    166698
    Feb 2012
    46
    Try going to Settings > Bluetooth, selecting the jawbone and forgetting it. If when the app starts working again, you can try pairing the Jawbone again and see if it still causes problems. You can also try the usual fixes, to see if they make a difference. I might just be a coincidence that the app is failing, and not the Jawbone at all. ------------------------------ The Usual Fixes ------------------------------ When you have problems with an app it's a good idea to clear it from RAM. Close/Clear the app: iOS 6: With the problem app closed, double tap on the Home button to get the multitask bar. Tap and hold on any icon in the bar until they jiggle, then tap the minus sign on the problem app. iOS 7: Double tap the Home button to get the multitasking display. Swipe up on the problem app's thumbnail image (not the icon). If that does not work try a restart, Restart: Hold down the power button until the power off slider appears. Slide it off. When the iPad finishes shutting down, hold down the power button again until the Apple logo appears. Apple recommends you restart the iPad at least once a month. and then a reset if that does not work. Reset: Hold down the power and home buttons until the Apple logo appears. The iPad will reboot. This usually takes a bit longer than a restart. Reset All Settings: Another, somewhat more drastic thing you can do is Reset All Settings. You'll find this under Settings > General > Reset > Reset All Settings. It won't erase any of your content, apps, or accounts; but you will have to go through most of your other settings and re-tweak them back to your liking. Do not confuse this with Erase All Content and Settings. More detailed information at: iOS: Not responding or does not turn on
    Thanks for your advice I would delete Jawbone and see if the app works
    1544 times
    Walla Walla, WA
    15,464
    No problem. Please let us know what happens.
  1. inspirational quotes
    By Jackryr in forum Off-Topic
    Last Post: Yesterday, 09:05 AM
  2. Replies: 0
    Last Post: 05-09-2012, 12:46 AM
  3. Tune in radio/french radio stations
    By Phine00Del in forum iPad Apps
    Last Post: 03-27-2011, 05:16 PM
