can't read magazines
This is a discussion on can't read magazines within the iPad Help forums, part of the Apple iPad Discussions category; I synced some magazine (pdf) to my Ipad 3 (IOS 7.04), but although I can see them in Ibooks, I can't open them up. In ...
Results 1 to 4 of 4
    309518
    Jan 2014
    I synced some magazine (pdf) to my Ipad 3 (IOS 7.04), but although I can see them in Ibooks, I can't open them up. In the right margin is the 'download' symbol (blue square inside a blue circle). What's going on??
    1524 times
    Walla Walla, WA
    15,434
    Not knowing for sure what you are looking at or what method you are using to sync PDF's to iBooks, I'd guess that the magazine is probably still in the process of downloading, possibly stuck. The blue circle with the square is a progress indicator. It starts with a thin line around the square that becomes thicker clockwise as the download continues. When the entire circle is thick, it is installing. The icon should disappear when the download is finished.
    I suggest the usual fixes, below, if you have not already tried them. If they don't work, please describe what you are doing in more detail and we can make another, hopefully better, guess.
    Good luck.
    The Usual Fixes
    Close/Clear the app:
    iOS 6: With the problem app closed, double tap on the Home button to get the multitask bar. Tap and hold on any icon in the bar until they jiggle, then tap the minus sign on the problem app.
    iOS 7: Double tap the Home button to get the multitasking display. Swipe up on the problem app's thumbnail image (not the icon).
    More detailed information at: iOS: Not responding or does not turn on
    309518
    Jan 2014
    synced mags
    Appreciate the help. Just noticed that the copies of the mags that have this issue are duplicates but I can't delete them when I try to edit them?? Nothing happens!????
    RK
    1524 times
    Walla Walla, WA
    15,434
    How did you move or sync these PDF's to iBooks?
    Details will help.
  1. Replies: 0
    Last Post: 07-03-2013, 01:27 PM
  2. iPad Magazines a Worthy Substitute for Print Magazines?
    By msmartinseo786 in forum New Member Introductions - Site Assistance
    Last Post: 01-10-2013, 12:49 AM
  3. Replies: 1
    Last Post: 12-17-2012, 01:19 AM
  4. Replies: 0
    Last Post: 11-10-2012, 11:24 PM
  5. Replies: 8
    Last Post: 07-01-2011, 10:33 AM
circle with square inside symbol ibooks
ibooks icon blue square in a circle
