Help on 3.2.1
This is a discussion on Help on 3.2.1 within the iPad Help forums, part of the Apple iPad Discussions category; Please some one help me out. I am running on a spirit jail break on 3.2.1. I went to do a restore and upgrade to ...
Results 1 to 1 of 1
Thread: Help on 3.2.1
    17983
    Oct 2010
    Ca
    Help on 3.2.1
    I am running on a spirit jail break on 3.2.1. I went to do a restore and upgrade to 3.2.2 and re jailbreak with limera. When I go to do a restore on iTunes I get an error that says that it can not it can not access the updater files. So in long story short I can't update anything in version.
    Another question I have is since I am jail broken, if I update and reinstall cydia will I loose all the changes that I have done with cydia as in terms of licenses. Thanks for the input.........
