Headphones won't insert
This is a discussion on Headphones won't insert within the iPad Help forums, part of the Apple iPad Discussions category; Dear all, I am looking for some help and/or advise. I went to put my headphones into my iPad 3 Wifi jack this morning as ...
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By scifan57
Thread: Headphones won't insert
    304916
    Oct 2013
    Dear all,
    I went to put my headphones into my iPad 3 Wifi jack this morning as normal and they wouldn't inset all of the way in. I have never had that issue before and nothing has happened to the iPad since yesterday which could have caused this to my knowledge.
    Basically when I try and pop in my headphones it feels blocked before the jack can be fully inserted... I have tried using a torch etc to see in there and can't see any obvious blockages...
    Any thoughts?
    Many thanks.
    Moderator
    131244
    1415 times
    Dec 2011
    Regina,Canada
    18,500
    Quote Originally Posted by Sierra Alpha View Post
    Dear all, I am looking for some help and/or advise. I went to put my headphones into my iPad 3 Wifi jack this morning as normal and they wouldn't inset all of the way in. I have never had that issue before and nothing has happened to the iPad since yesterday which could have caused this to my knowledge. Basically when I try and pop in my headphones it feels blocked before the jack can be fully inserted... I have tried using a torch etc to see in there and can't see any obvious blockages... Any thoughts? Many thanks.
    Have you checked to see if the headphone plug is bent? Even a tiny bend will cause it to jam in the jack before becoming fully seated.
    304916
    Oct 2013
    Quote Originally Posted by scifan57 View Post
    Thanks for the reply. Yes I have, and it isnt - I have also tried other pairs of headphones - they simply wont go in far enough to 'dock'.
    Thanks.
    Moderator
    131244
    1415 times
    Dec 2011
    Regina,Canada
    18,500
    Thanks for the reply. Yes I have, and it isnt - I have also tried other pairs of headphones - they simply wont go in far enough to 'dock'. Thanks.
    if there is no visible blockage in the headphone jack and no headphones will plug in properly, it may be time to have it checked out at the Genius Bar at the closest Apple Store. If the jack is defective, it 's a hardware issue and should be covered under warranty or AppleCare.
    304916
    Oct 2013
    I have an appointment booked already and am no longer under warrenty unfortunately. Just wondering if anyone had any suggestions for maybe investigating a blockage further.
    Moderator
    131244
    1415 times
    Dec 2011
    Regina,Canada
    18,500
    Have you tried using the suction from a vacuum cleaner with a small nozzle fitting? It may suck out anything trapped in the socket.
    abababababab likes this.
    304916
    Oct 2013
    Good idea - I will try this when I get home.
    Thank you.
  1. Replies: 1
    Last Post: 07-14-2013, 08:01 PM
  2. sim insert.
    By zen2013 in forum iPad General Discussions
    Last Post: 03-06-2013, 08:20 PM
  3. Insert a Hyperlink
    By Grinchy in forum iPad Help
    Last Post: 07-23-2012, 09:55 AM
  4. I need help! Can i insert information?
    By alpinpad in forum iPad Help
    Last Post: 08-10-2011, 11:35 AM
headphones wont click into jack
headphones wont fully insert into jack
ipad cant insert headphones
