Help can't send email
This is a discussion on Help can't send email within the iPad Help forums, part of the Apple iPad Discussions category; Pulling my hair out. I had a pop up asking for a password for an exchange account I never had. Tech at the apple store ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
    224905
    Jul 2012
    21
    Pulling my hair out. I had a pop up asking for a password for an exchange account I never had. Tech at the apple store suggested deleted the account he thought was responsible then reinstalling email. Using the same settings I did before and the same ones that work for my android, the outgoing server doesn't work. I've tried different port numbers and turning ssl on and off. All combos possible. Any ideas?
    iPad Guru
    49414
    467 times
    North Carolina
    3,128
    Quote Originally Posted by wade2677 View Post
    Hi Wade - I think that many of us know the feeling - You might want to provide some more information first: 1) What iPad model & iOS are you using; 2) What email clients are in your iPad Mail account (e.g. Yahoo, Gmail, etc.); and 3) What is your local home network (ISP, modem type, etc.) - just a few questions for starters - Dave
    Attached Thumbnails Attached Thumbnails Help can't send email-pulling_hair_out.jpg
    224905
    Jul 2012
    21
    Quote Originally Posted by giradman View Post
    It's an ipad2 recently replaced because of a broken screen. But before you say anything, after reinstalling from iCloud everything was exactly the same including the annoying pop up. IOS7 from the store when I took it home. I have 4 gmail accounts I sync but only calendars for my workers. My email is an outlook version 2003 from my office. I use a netgear wireless modem at home. I simply deleted the account and was going to reinstall. Even took a picture with my phone of my settings before deleting but just won't work.
    iPF Expert
    258192
    1673 times
    Nov 2012
    Apetlon, Austria
    8,625
    Is it a work account, do/did you have a profile installed?
    Try to delete the account and set it up with Outlook.com, not as Exchange.
    Johanna A.
    You will recognize your own path when you come upon it, because you will suddenly have all the energy and imagination you will ever need. ~ Jerry Gillies
    224905
    Jul 2012
    21
    Quote Originally Posted by J. A. View Post
    It's a pop3.
    iPad Ninja
    219668
    368 times
    Jun 2012
    California
    1,944
    It's a pop3.
    The offending one or the one you use?
    Can you screen shot the message (without any private info)?
    You said it is an account you have never had, what provider/host is the account on?
    This is a tough one without seeing the issue live, it can be something as simple as a mis-typed address for the server, port, account name etc. or (and it sounds like you have tried changing them) incorrect port assignments. Is it a Pop account that requires SSL (usually where you might have the incorrect port assignment) or not (I know you switched back and forth)?
    Sorry for all the questions, and you probably looked at these, but....
    224905
    Jul 2012
    21
    The original message.
    The message I get now. I took a pic with my phone of the settings I had before I deleted the account to put them back in exactly as they were. The one I've used for years and am currently trying to reinstall is a pop3. Tried 25, 26, 465, and 587 for outgoing ports. All with password on and off and ssl on and off and all combos. Baffled here big time. Incoming works fine. May have to take a trip to the apple store.
    iPF Expert
    258192
    1673 times
    Nov 2012
    Apetlon, Austria
    8,625
    If you have another email account, try using the SMTP server from that one. If this works, there's something wrong with the SMTP settings in Outlook.
    And just to check: username and password are entered in "Outgoing Mail Server"?
    Johanna A.
    224905
    Jul 2012
    21
    I tried another one that one of my employees uses. It's the same settings and his didn't work either. For outgoing the user and pass are optional but I used them and didn't use them on separate occasions. When you say another email do you mean another outlook or a yahoo, gmail, etc?
    iPF Expert
    258192
    1673 times
    Nov 2012
    Apetlon, Austria
    8,625
    I meant another email account installed on your iPad.
    Johanna A.
  1. Cant send email
    By Spookirules in forum iPad Help
    Last Post: 12-29-2011, 01:47 PM
  2. Replies: 3
    Last Post: 10-30-2011, 10:03 AM
  3. Can't send email
    By bgfdps in forum iPad Help
    Last Post: 10-22-2011, 07:49 AM
  4. Can't send email
    By kategalway in forum iPad Help
    Last Post: 05-23-2011, 07:43 AM
can't send email ios7
can't send mail
